Fuel pump stays running when key on engine off??
My 94 is doing the same thing but my high speed fan stay on too an I replace the ccrm an it is still doing the same thing an my car is running bad with the fuel pump on the car sound like it has a cam but if I turn it off the car run fine so could this be a bad computer
If your car is doing the same thing, I would read out pins as described earlier in this thread if you have already swapped the CCRM. These days you should be able to find a 94/95 ECU pretty cheap / easily at a junk yard. Worth a shot.
