Fuel pump?
  • Thread starter Thread starter RsStanG1987
  • Start date Start date Sep 17, 2004
RsStanG1987
I shaved all my pubes playing this game.
569
9
79
Dupont PA
Sep 17, 2004
  • Sep 17, 2004
:ike half an hour ago i went to start my car and it started up and just died. I went to start it back up and nothing it just cranked. I turn the key over and do not hear the fuel pump prime. Is there a relay for this i can check? I need help quick im at work.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 17, 2004
  • Sep 17, 2004
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park. Remove coil wire from distributor & and hold 3/8” away from engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) Coil
B.) TFI module
C.) PIP sensor in distributor
D.) ECC relay next to computer
E.) Fuse links in wiring harness
F.) Ignition switch
G.) Computer
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
If it starts then, you have a fuel management issue. Continue the checklist with emphasis of fuel related items that follow. If it doesn’t ,then it is a computer or timing issue: see Step 4.
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the lower RH corner to ground. See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html for a description of the test connector. If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In pinch you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have
No fuel pressure, possible failed items in order of their probability:
A.) Tripped inertia switch – Coupe -& hatch cars hide it under the plastic trim covering the driver's side taillight. Use the voltmeter or test light to make sure you have power to both sides of the switch
B.) Fuel pump power relay – located under the driver’s seat in most stangs built before 92. On 92 and later model cars it is located below the Mass Air Flow meter.
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness.
F.) Fuel pressure regulator failed. Remove vacuum line from regulator and inspect for fuel escaping while pump is running.
4.) Spark & fuel OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off only likely if the engine has been worked on recently).
D.) Firing order off: HO & 351 use a different firing order form the non HO engines.
RsStanG1987
569
9
79
Dupont PA
Sep 17, 2004
  • Sep 17, 2004
is there another relay under the dash?
D
Daggar
3,902
  • Sep 17, 2004
The relay is under the driver's seat.
RsStanG1987
569
9
79
Dupont PA
Sep 17, 2004
  • Sep 17, 2004
I checked everything else, There is spark and everything so it must be the relay? Or at worse the fuel pump right?
D
Daggar
3,902
  • Sep 17, 2004
Fuel pump, relay, fuse, ignition switch, wiring. Not necessarily in that order. If none of that jumps out at you then I'd get a fuel pressure pressure guage to confirm or rule out a pump or pump system problem. If that checks out... I'd go through jrickter's checklist (you can find it repeatedly posted on many threads) and diagnose the problem that way.
RsStanG1987
569
9
79
Dupont PA
Sep 17, 2004
  • Sep 17, 2004
Where is the fuse?
HISSIN50
34
129
Sep 18, 2004
  • Sep 18, 2004
RsStanG1987 said:
Where is the fuse?
the fuel pump uses a fusible link, not a fuse. the link is off the solenoid.
you cant beat JR's list for a complete and organized listing of what to check. im with Daggar on what to do - ill add to it.
assuming you are right about no pump priming: were it me, i would pull the FP relay. whip out the DMM and check the values. make sure you have the coil triggers (if missing positive coil, check the inertia switch in the trunk). puter sends ground. then the solenoid fed wiring goes to the common terminal. then output.
go from there. good luck.
RsStanG1987
569
9
79
Dupont PA
Sep 18, 2004
  • Sep 18, 2004
I checked the fuse the inertia switch and changed the relay so. So does that mean the fuel pump is bad??? Do they just go bad out of nowhere?
M
mustangman33
262
Chicago, IL
Sep 18, 2004
#10
  • Sep 18, 2004
  • #10
Just went thru similiar issues with my 95, took me months to figure out the problem, when you turn the key on you should hear the pump prime, if not I would grab like a pin or something, that little thing on the fuel rail that looks like a valve stem, push down on the pin inside and fuel should squirt out, then you will know if fuel is getting to the fuel rail.
HISSIN50
34
129
Sep 18, 2004
#11
  • Sep 18, 2004
  • #11
what did you find when you checked each terminal in the FP relay socket? that will tell you what direction to go. this will also tell you if it is the pump. one can jump the self test connector to make the pump run (for diagnostic purposes). JR listed a link to it in his post.
as opposed to depressing the schrader valve on the fuel rail, get yourself a FP gauge - be it a permanent gauge or a diagnostic gauge. see what (if any) pressure you have. if you have too little pressure, get back to us (testing info to determine whether it is pump related or FPR related can be given).
good luck.
RsStanG1987
569
9
79
Dupont PA
Sep 21, 2004
#12
  • Sep 21, 2004
  • #12
It was the fuel pum somebody told me to have someone hold turn the key as if i were turing the car over and hit the tank with a rubber mallet and see if it primes. sure enugh it did. I got a new pump and the car runs great. Thanks for the help
HISSIN50
34
129
Sep 21, 2004
#13
  • Sep 21, 2004
  • #13
well that is one way to check it (i might have simply confirmed that the pump was getting power from the relay socket and/or at the pump or run it from the self test connector). but the RUBBER hammer method always works.
glad to hear it is good to go.
  • Mindseye007
  • Aug 16, 2026
Mindseye007
Engine Fuel not pumping
  • Creomod
  • Apr 13, 2026
  • 2 3
Fox 5.0 Mustang Tech Jul 22, 2026
1997 gt Starts then dies a few seconds after.
  • 97orange
  • Aug 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 17, 2026
97orange
9
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
