fuel pump
  • Thread starter Thread starter N242
  • Start date Start date Feb 16, 2008
N
N242
90
  • Feb 16, 2008
hi
i have mustang 67
302 engine late model (not ho )
holley 4150 600 CFM dp
i don't know what fuel pump batter for me
electric fuel pump or mechanical fuel pump
if i chose the mechanical option i need a new timing chin cover whit hole for the pump
so what are u thinking better for me ?
93 LX
3,081
Norwalk, CA.
Feb 16, 2008
  • Feb 16, 2008
get a good mach pump. I have a carter HP pump I bought many years ago. My 302 spins to 7 grand and under some hard street runs it never leans out. I have a 700 CFM DP carb too.
93 LX
3,081
Norwalk, CA.
Feb 16, 2008
  • Feb 16, 2008
btw yes you will need a new timing cover and cam eccentric as well
N
N242
90
  • Feb 16, 2008
so you thinking that i need to change the cam also
if i use whit mechanical pump ?
N
N242
90
  • Feb 18, 2008
93 LX
3,081
Norwalk, CA.
Feb 18, 2008
  • Feb 18, 2008
no there is an attachment that goes on the cam gear. The pump is driven off this attachment. If you go to the boine yard and remove a mech pump and timing ocver you will understand. I mena how else if the mechanical pump driven? They are all drivine off the cam, chevy uses a lobe on the cam, ford using a loble that is attached to the front of the cam and it touches the pump arm to drive the pump.
N
N242
90
  • Feb 22, 2008
ok
i think that i go whit the electric pump .
what are u thinking about the holley red pump ?
N
N242
90
  • Feb 26, 2008
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
A
Resolved 302 still running after turning off ignition
  • AlexM556
  • Saturday at 4:37 PM
Classic Mustang Specific Tech Sunday at 5:17 PM
AlexM556
A
FUEL PUMP ALWAYS ON
  • Scwhitten
  • Jun 6, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 5, 2026
Scwhitten
D
Engine 85 GT Backfires through Carb
  • DienstXIV
  • Oct 3, 2025
Fox 5.0 Mustang Tech Oct 7, 2025
85GTStangGuy
