Fuel Rail Help.
  • Thread starter Thread starter MikeROD16
  • Start date Start date Mar 9, 2008
MikeROD16
Miami, FL
Mar 9, 2008
  • Mar 9, 2008
so i got these fuel line disconnect tool from AmPro, its metal and kinda looks like a scissor. but i cant seem to disconnect the fuel rail. i slipped it in the line and it made the sping expand a little but i tried pulling them apart and nothingggg. im so frustrated. plz, if you have any tips, tell me.
BYRDPE
1,556
Memphis,Tn.
Mar 9, 2008
  • Mar 9, 2008
Keep at it...it'll come loose.
With the tool installed push the rails together, wiggle them and pull.
You can spray some WD40 in there to loosen up some of the crud in there.
I
irish
168
Florida
Mar 9, 2008
  • Mar 9, 2008
Usually there is crap in there as mentioned earlier which prevents you from getting the fitting all the way in, I twist it back and forth abit and usually it goes in and you can separate the fittings.
Matt
vristang
4,933
101
124
Seattle
Mar 9, 2008
  • Mar 9, 2008
fuel lines are a beotch...
Keep pulling on them, they'll break loose.........
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Mar 10, 2008
  • Mar 10, 2008
I have the little plastic tools, I just sprayed a little PB Blaster in there and was able to work the line off.
D
After Market fuel rails with Stock fuel lines
  • dropteeth
  • May 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 2, 2026
2000xp8
getting 90 PSI at fuel rail - help
  • skidad
  • Oct 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
skidad
N
89 LX 5.0 Fuel Rail Recommendations
  • Ncarter
  • Oct 17, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 18, 2025
rednotch
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
A
Resolved Fuel pressure high at 52 new FPR same thing
  • afjLX
  • Dec 28, 2024
  • 3 4 5
5K
Fox 5.0 Mustang Tech Jan 11, 2025
AeroCoupe
