fuel rail mounted guege?
frcefedlx
184
I had an electric fuel pressure guage on my 93' lx and used a fitting that screwed into the schreader valve. I figured that same fitting would work on my
94' Cobra. The fitting has a 1/16"-27 male npt fitting and a 1/8"-27 female npt fitting. The male end is the same size as the outside diameter threads on the schreader valve, no way it is going to thread into the valve. I did a search on this and found that the very same fitting I am using is the one every one is having success with. I can only find one NOS fitting that will work on the threads on the outside of the schreader valve, but apparently the only place I can get it is Summit and it would cost more for the handling than the part itself. Was there a change in the fuel rails or something. I do not understand why what everyone else is using doesn't apply to my car.
