Fuel Rail?
  • Thread starter Thread starter 89oem
  • Start date Start date May 25, 2014
89oem
Mustang Master
Dec 18, 2013
1,456
542
144
May 25, 2014
  • May 25, 2014
so madspeed scared me.... i have a stock fuel rail that came with my cobra intake... i had been wondering about the cross tubing now im thinking no way....since ill have bigger fuel pump and pressure...
what fuel rail does everyone run / recommend? strong street hci build...
madspeed
Colonel Mustard
1,332
204
a van down by the river
May 25, 2014
  • May 25, 2014
Bigger pump only keeps the flow adequate to support your engines needs. More pressure? Do explain....
89oem
Mustang Master
Dec 18, 2013
1,456
542
144
May 25, 2014
  • May 25, 2014
i figure a larger pump 340... will run more fuel through the lines, more volume = more pressure im also going bigger lmaf and matching 42 injectors... tune will balance it all but my understanding is the fp may be greater than stock... reason for going big = future SC...
am i wrong on the volume = pressure?
madspeed
Colonel Mustard
1,332
204
May 25, 2014
  • May 25, 2014
yes you are incorrect, the pressure will remain the same as it is now
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
May 25, 2014
  • May 25, 2014
Unless it's a high pressure pump, it will not increase pressure at the rail....and even still, the regulator is going to dumb it down to 40psi.
Not sure why you would consider a 340lph pump. A HP255lph pump will more more fuel through the stock rails than they're able to handle anyway (about 500hp N/A). The 340lph pump is reserved for people with large fuel rails and the need to support 500+hp. Kind of a waste of money for everyone else. You'll never max out a HP255lph pump with stock rails and a stock block.
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
May 25, 2014
  • May 25, 2014
The stock fuel rails will easily support 450hp. The FPR and EEC keep the fuel pressure regulated. I believe the issue with Mad was the stupid schrader mounted fuel pressure gauge that no one should ever consider.
89oem
Mustang Master
Dec 18, 2013
1,456
542
144
May 25, 2014
  • May 25, 2014
thanks! im off base then....so the rails and cross over never see more pressure than regulator/ecu allows and that is beyond what id approach anyway... ?
i was thinking since it was on the return side ?? it caused more backup pressure than being on feed side allowing more flow through volume.... dam vs tap..... is that right?
considering it was a closed loop system, i assumed increased volume that much larger pump would deliver through the same fixed space would increase pressure in the whole system and that the regulator just controlled volume/pressure as required by the injectors via the ecu...and that was where the actual point of reference occurred for regulation...the orifice of the injector telling the ecu what it wanted for said volume via the table...
what i now understand is that unless the rails suc k and are faulty there is no issue..... ill go with what i have then...
im actually getting a really good deal on a new aeromotive 320...
* sorry mad, i thought you had said something about your sn95 rail crossover...
madspeed
Colonel Mustard
1,332
204
May 25, 2014
  • May 25, 2014
judging from the carnage, I believe it actually was the fuel crossover line split. The worst of my burning was done right at the distributor. I still will not run a rail mounted gauge any longer for safety sake
89oem
Mustang Master
Dec 18, 2013
1,456
542
144
May 26, 2014
  • May 26, 2014
for a hundred or two dollars in parts, think ill go with piece of mind.....
so aeromotive, bbk, trickflow, edelbrock, others? whose rail is best option?
im thinking using braded fuel lines from/to the source / return lines - maybe russell?
i dont like the rubber tubing bbk uses but it is the least expensive... the accell and mallory have the return coming from the middle of the rail??
thanks for the help!
Spaz
80
11
Pennsylvania
May 26, 2014
#10
  • May 26, 2014
  • #10
I have the Russell braided lines and Professional Products fuel rails and fuel pressure guage. Very happy with the Russell lines. The rails not so much. It took a few modifications to get them to fit right, and a couple of tries to get them to stop leaking. Mainly there was zero customer service. I tried contacting PPI a couple of times with questions and never got a response. Everything works fine now though. I just was on my own figuring it out.
RacEoHolic330
I like to dress like a pretty girl
4,014
1,698
203
Allentown, PA
May 26, 2014
#11
  • May 26, 2014
  • #11
I prefer Glenn's or Behind Bars Race Cars fuel rails personally. Don't get a rail that has the return in the middle of one of the rails. That's a poor design, IMO.
89oem
Mustang Master
Dec 18, 2013
1,456
542
144
May 26, 2014
#12
  • May 26, 2014
  • #12
Thanks Scott, ill look those up... thanks for confirming the accell/mallory is just off somehow....
Thanks Spaz! so no to PPI products, but Russell is a good plan if braided not part of 'kit'
others???
89oem
Mustang Master
Dec 18, 2013
1,456
542
144
May 26, 2014
#13
  • May 26, 2014
  • #13
nice sites @RacEoHolic330 ! not cheap but really nice, are you running their braded nylon supply lines or did you run stainless or stock?
got a feeling my budget just expanded....
RacEoHolic330
4,014
1,698
203
Allentown, PA
May 26, 2014
#14
  • May 26, 2014
  • #14
I run TechAFX PTFE (teflon) braided stainless lines with Fragola fittings. I didn't want to deal with the potential of braided rubber lines leaching fuel vapors after a few years. Fuel systems are expensive man. I wouldn't replace your stock lines until your power levels demand it. Once you start replacing lines, you're no longer in the couple hundred dollar range.
89oem
Mustang Master
Dec 18, 2013
1,456
542
144
May 26, 2014
#15
  • May 26, 2014
  • #15
cool, just planning for the inevitable darn that looks bad scenario....
'while we're at' - norm abrams
89oem
Mustang Master
Dec 18, 2013
1,456
542
144
May 26, 2014
#16
  • May 26, 2014
  • #16
this techAFX ?
BlackWrap Braided SS PTFE Hose (conductive core)
-6, -8, -10 what size?
gotta assume its the fittings that run up the cost...
this may address my increased volume via aeromotive 320, better rails, adjustable fp gauge (for tune...)
all overkill but a long term do it once strategy....
madspeed
Colonel Mustard
1,332
204
May 26, 2014
#17
  • May 26, 2014
  • #17
You mean adjustable fuel pressure regulator
89oem
Mustang Master
Dec 18, 2013
1,456
542
144
May 26, 2014
#18
  • May 26, 2014
  • #18
you are correct regulator...
RacEoHolic330
4,014
1,698
203
Allentown, PA
May 26, 2014
#19
  • May 26, 2014
  • #19
I ran a -10 feed and -8 return, but I have a 1000hp capable setup. With your 42lb injectors, your stock lines will flow more fuel fuel than your injectors will need. It will probably cost you a grand to build a PTFE fuel system. The fittings cost a pretty penny.
89oem
Mustang Master
Dec 18, 2013
1,456
542
144
May 27, 2014
#20
  • May 27, 2014
  • #20
thank you, i was guessing around 600... so no need unless lines are shot....ok
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
N
89 LX 5.0 Fuel Rail Recommendations
  • Ncarter
  • Oct 17, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 18, 2025
rednotch
J
Engine Running like crap :(
  • justadude07
  • Sep 27, 2025
Fox 5.0 Mustang Tech Oct 19, 2025
DadLife0724
  • dan50
  • Jul 18, 2026
dan50
