Fuel rails and distributor
brian69
17
Finally ready to put new combo in my car and had another question.
All aeromotive fuel syst. front to rear with a y-block feeding the rails and returning
to regulator in -8, dual lines in and out.
Now for my question, Will the stock distributor work or will the lines hit?
If it wont work what dist does fit?
not sure if I understand your setup the way you have it written. you should have a feed line to each rail, then from each rail to the regulator with a single return from the regulator back to the tank.
you might have to use a 45* fitting on the drivers side front to get around the dizzy. or use 180* fittings from the front of the rails and run the lines back behind the intake.
