Have a 91 LX 5.0, Gt 40 intake, underdrive, pulleys, Ford Motor Ceramic Shorty Headers,2.5" exhaust, X-pipe, flowmasters, 190LPH fuel pump, rockers(because of the taller valve covers I assume) , I think upgraded fuel injectors (because theyre so LOUD) E303 cam, 73mm Vortech throttle body or is it the mass airflow?K&N, Steeda springs, subframe connectors, 3.55's Oh well - anyway- Trying to solve two problems and I think they may be related. I'm not sure on some things on the car because I just bought it - Others I know cause I have the Steeda Invoices of what was done (and some of their codes I can't decipher)
Ok - first One - idle is set to about 800-900 rpm It idles fine - however when I'm driving, it seems I can let my foot off the gas and "idle" at cruise speed; and when I stop at a light - the Idle hangs at about 1500 rpm and gradually (SLOWLY drops) to about 1100, and then if the light is long enough, it will all of a sudden DROP back to the normal 800/900 Idle it's set to. Cruise control works fine... um Throttle body spring SNAPS back when I do it with my hand... Is this a vacuum issue? or something Inside the throttle body housing?? any suggestions would help -
Also 2nd issue I have - it seems that gasoline smell permeates through the firewall - My wife and I have noticed it and its given me headaches before.. I dont SEE any evidences of fuel being spilled anywhere or anything tangible - however the injectors DO seem unusually loud...??also noticed that the smog pump i removed from serpentine system, and it seems the EGR is plugged up as best it can be - this was my initial suspision. Should I remove the pipe that extends from off the back of the heads and intall plugs back there? and the 190LPH fuel pump is it necessary on this particular setup? does this effect fuel economy or just fuel line pressure or potential fuel delivery?
So many questions - sorry to ramble - any help is appreciated.. THanks!
