Fuel Sump?
tjh566
608
Northern Va
Haven't been on here in awhile.. finally starting to get back to a point where I can work on my car again.
So here's the question.. Do I really need a fuel sump? Or can I just use one of these nice pickups like this one: Glenn's Performance
My reasons for this is because first off I have a fuel problem now, I think one of my pumps failed so every time I hit boost my car just falls on its face hard and my future plans are 1000hp+.
So I'm Just planning on scrapping my 2 pump setup here and get a nice big in-line fuel pump and upgrade to a -10an feed line and a -6an return.
:SNSign:
lol, why would you even think that, If im mechanical able enough to custom fit an eaton and self tune my car, I wouldn't be dumb enough to think that eaton could do it.
going 351 swap and turbo
Ok, just checking. I had a friend who just set up a Pro Turbo kit with one of those pickups. He's running a big Aeromotive pump on it.
Kurt
the reason I ask is the pump i'm looking at says it requires a sump I just want to be sure ill be ok and don't have to run around with a 1/2 tank minimum, I mean ill never let it go below a 1/4 tank i just don't wanna have to worry about it.
Rear Sump
I have one of Glenn's kits with a rear sumped tank and I have had no issues below 1/4 tank. The only negative for me is the sump is pretty big and sits kind of low. I know the sleeper tanks are supposed to do pretty good too.
Good Luck.
