On an EFI application, the return line is not pressurised, and the return feed actually goes to the drain hole. Sorry for that error in the drawing. The regulator holds a specific pressure of fuel in the line and returns what is not needed to the tank. The reason to "T" into the tank outlet line (in my simplistic theory) is that I am trying to avoid the "air sucking" problem with the non-baffled tank. At that point in the system, the line is still non-pressurized, so, all I am doing is providing another source of fuel to the inlet line of the pump. If the fuel is not needed it would continue on to the tank. Right?
