Fuel system overkill????
  • Thread starter Thread starter Informant736
  • Start date Start date Apr 18, 2006
I
Informant736
44
Malvern, PA
Apr 18, 2006
  • Apr 18, 2006
I have an 89 coupe that i blew the motor on from using nitrous and am putting it back together slowly. I got a fresh motor with 1.7 rr and a slight port job done to the heads and the intake is ported as well(both stock). I have 24lb injectors and a 75mm MAF to match it, i plan on getting some goodies with my tax refund and a 150lph fuel pump was one of the things i was considering. Is this goin to be overkill on my car? I plan on running the nitrous still, its a dry system, and i also plan on getting bigger heads and intake once i get this thing back on the road. I figure i should be ok but would like some other peoples inputs. Thanks
Clienterror
22
  • Apr 18, 2006
No it sounds fine, 24lbers may be a tad big for stock setup but sicne your useing dry nitrous 24's are a good choice along with the 75mm MAF may be a little big, more like 70mm. Most people just buy the 255lph pump and get it over with since it only costs a little more. Other than that it wont blow up with nitrous use and it should run good.
50gt1988
154
Spanaway, WA
Apr 18, 2006
  • Apr 18, 2006
go with a 255lph while your at it, extra fuel will just be sent back to the tank by the FPR
D
Fuel pump upgrade
  • dkrupp79
  • Jul 7, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 10, 2025
Scrapla347
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
Fox won't crank over and fuel pump won't kick on.
  • djj62478
  • Jun 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
General karthief
