  • 2005 - 2009 Specific Tech
Fuel
  • Thread starter Thread starter TinMan09GT
  • Start date Start date Apr 13, 2009
T
TinMan09GT
11
PA
Apr 13, 2009
  • Apr 13, 2009
What octane rating you guys running in your cars? i run Super (93) but the manual says only to run regular (87) in it? just wondering y and if theres a reason?
white07gt-cs
103
  • Apr 13, 2009
If your car is stock, you are just wasting money for the most part. In a lot of engines designed and tuned to run 87 octane, the performance will actually be worse with 93. This is primarily due to the slower burn rate of higher octane fuel.
That being said, if you change parameters by such as advancing timing, then the higher octane and more stable burn rate will be necessary.
Bottom line, if you're running a stock built and tuned car, use 87 octane and save your pennies for mods that will require them.
NastyStang113
1,567
Florida
Apr 13, 2009
  • Apr 13, 2009
Exactly. If you're tuned for 93 than run it. If you've got a stock car with factory programming stop wasting your money.
Art161
130
San Francisco
Apr 14, 2009
  • Apr 14, 2009
I have the stock tune and use Chevron 87 octane. Back in the old days, the premium grade had a better additive package than the regular grade. In the case of Chevron, that is no longer true. The additive package for all their gasoline sold in the United States is the same. I didn't ask the other companies, because I use only Chevron. I happen to think that the Techron in Chevron is good stuff.
G
Octane on the 5.0 Coyote
  • gray owl
  • May 17, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk May 27, 2026
Bullitt347
W
2016 Mustang GT fuel tank leak
  • Waynetk16
  • Oct 8, 2026
2015 - 2023 (S550) Mustang -General/Talk Oct 9, 2026
gkomo
C
Fox 1993 LX 2.3 help identifying this
  • Coyoteswap93
  • Jul 17, 2026
AeroCoupe
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
T
First Car, what should I do for power??
  • tunedV6
  • Apr 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 4, 2026
580HP*428Cj
