fumes????
  • Thread starter Thread starter jimsstang91
  • Start date Start date Apr 11, 2006
jimsstang91
101
  • Apr 11, 2006
i am getting alot of fumes i can't even walk in the garage. fuel pressure is at 40psi. injectors hold pressure. there are no cats.
HISSIN50
34
129
Apr 11, 2006
  • Apr 11, 2006
When does this occur? While the car is off, while idling in the garage, at all times, etc?
Good luck.
jimsstang91
101
  • Apr 11, 2006
just when it idles in the garage. i don't smell gas. but it's so bad it's like i'm crying.
HISSIN50
34
129
Apr 11, 2006
  • Apr 11, 2006
The lack of cats is probably simply allowing emissions to dump a bit more than normal. If there isnt adequate ventillation in the garage, even with cats I can get a headache.
Now if you smell or feel that actual gas fumes are escaping, that isnt good and is a possible recipe for an explosion (as JRichker points out, a gas or fuel vapor leak and pilot lights for water heaters, etc, dont mix).
jimsstang91
101
  • Apr 11, 2006
no, it's all fumes. but i think i know why, the tailpipes are facing the wall and the nose is at the opening of the garage. but i even if i walk to the back of the car eyes water in a second.
HISSIN50
34
129
Apr 11, 2006
  • Apr 11, 2006
I cant say that it's normal, but if I back into the garage, I get fumed out myself. If you can open a back door or window it will help a lot. Be careful with CO! Bump for you.
troyGT03
278
too close to memphis,tn
Apr 11, 2006
  • Apr 11, 2006
turn the car around. 5.0's are super rich on warm up anyways. what mods do you have? is the 40 psi with vac on or off the fpr?
jimsstang91
101
  • Apr 11, 2006
40 is with the line off and pluged.
T
Engine Need help figuring out misfire and backfire
  • trystancounts
  • Sep 25, 2025
Fox 5.0 Mustang Tech Sep 26, 2025
K
88 speed density misfire and bucking
  • kush
  • May 29, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
DadLife0724
Forced Induction Bypass valve reference
  • JD1964
  • Jun 1, 2025
Fox 5.0 Mustang Tech Jun 1, 2025
JD1964
Resolved Three way cat converters..?
  • PonyGTrider
  • Nov 2, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 2, 2025
PonyGTrider
Fuel Bad regulator diaphragm?
  • JD1964
  • May 20, 2025
2K
Fox 5.0 Mustang Tech Jul 16, 2025
JD1964
