Special problem...
This is on a 1990 LX
Car will not start the first time when cold. It takes a few attempts to start, then it starts fine. but when the O2 get going, the car wants to die...and it does sometimes.
If I pull off the MAF sensor power, the car goes into "limp home mode" and runs fine. If I start with a cold car and just pull the MAF sensor connector loose, the car will start and idle perfect. If I shut it down and reconnect the MAF sensor, then engine stumbles and you can hear it sucking air. Connecting and disconnecting the MAF is only to get it in Limp Home Mode. The sensor works fine and everything about the sensor tests fine.
Disconnecting the EGR sensor put the computer in limp home mode too.
It's my understanding that if the check engine light is on, the computer is in limp home mode. Please correct me if I'm wrong.
My questoin is....
What sensors are cut out of the loop when in limp home mode, and which sensors are operating.
It's really funny how it idles perfectly with the check engine light on. Then when you fix that, it runs bad.
Any help will be appreaciated!!!!
Thanks
Jim
My questoin is....
Thanks
Jim
