Fuse Link to Fuel Pump Relay
miksax
48
I have found the fuel pump relay, and I am trying to check the voltage. I have read that the wire from the fuse link is pink/black, but I cannot find this color wire. Instead, I have a wire that is black with a thin yellow stripe. Is it possible that I am totally looking at the wrong wire? If I have the correct wire for the fuse link, where does it start at? I am also looking at the starter solonoid for this fuse link, but I cannot find it. Any help understanding this is appreciated.
Thanks
Blk/yel is probably the wire to energize the FP. You need to tell us what year of stang you have; the FP wiring changed in the middle of the aero fox run.
There will be two fat wires at the relay. The one that doesnt have constant power is the wire that goes to the FP itself.
