fuse problem
  • Thread starter Thread starter fastfiftyragtop
  • Start date Start date Oct 6, 2005
F
fastfiftyragtop
  • Oct 6, 2005
i have a 1990 gt convertable and i recently replaced the factory radio with a jvc. everything worked well for a while until the fuse blew, so i tried to change it and it blew every time i put a different one in. even when i disconnected the radio from that fuse, fuse 8. fuse 8 controls the radio, the dome lights trunk light, glove box light and cigarette lighter and none of them work. Do i need to check all those wires to find the problem??? has anyone had this problem? any advise?
9
92Patrol5.0
1,076
Cedar Rapids, Iowa
Oct 6, 2005
  • Oct 6, 2005
If you disconnect the radio and put a new fuse in, does the fuse still blow? Or does it blow even if the radio isn't connected? If the radio is doing it, maybe check to make sure all the radio wires and connected properly, no bare wires touching each other that shouldn't be, etc.
ss93cobra
1,422
Wilmington NC
Oct 6, 2005
  • Oct 6, 2005
Check the cig. lighter. I've had this issue on a couple of different cars, and I've ended up disconnecting the lighter socket completely.
HISSIN50
34
129
Oct 6, 2005
  • Oct 6, 2005
I cant remember if the lighter is on the radio circuit, but if so, SScobra is right. A piece of change can fall into the lighter receptacle and short the power to ground.
92P5.0 suggested just what I would do too. BTW, congrats on the 1K posts milestone.
Good luck.
F
fastfiftyragtop
  • Oct 8, 2005
yes, even when the radio is disconnected it blows the fuse. ill try disconnectng the cig lighter and let u know what happens. thanks for the help everyone!
Electrical Parasitic Draw, Fuse 8
  • N8827N
  • Sep 15, 2026
Fox 5.0 Mustang Tech Sep 18, 2026
AeroCoupe
Electrical Fuse 8, Light Green / Black Wire
  • bleedinggreen
  • Jun 23, 2025
Fox 5.0 Mustang Tech Jun 26, 2025
bleedinggreen
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
G
Help! Radio, door chime fuse keeps blowing.
  • goofyfoot53
  • Sep 9, 2025
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Sep 9, 2025
91AOD5.0LX
Y
2004 Roush - Dome Lights and radio not working
  • Yurei
  • Nov 10, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 20, 2025
squeak93
