  • 1994 - 1995 Specific Tech
FUSE Problem
  • Thread starter Thread starter hollywoodstang
  • Start date Start date Oct 30, 2006
hollywoodstang
1,095
Oct 30, 2006
  • Oct 30, 2006
Everytime i put my gear in reverse my tail light fuse blows out...
can anyone help me with this problem??? the fuse is 15A.
hollywoodstang
1,095
Oct 30, 2006
  • Oct 30, 2006
Everytime i put my gear in reverse my back up light and convertible top and airbag fuse goes out(15A) the fuse is #1 position. can anyone tell me what is wrong? or anyone experienced this problem?
thanks
Killercanary
The car that set the bar.
Altoona, PA
Oct 30, 2006
  • Oct 30, 2006
You had two threads, so I merged them into one. Sorry, I don't know the answer to your question though.
HISSIN50
34
129
Oct 30, 2006
  • Oct 30, 2006
The back-up light switch is on that fuse, IIRC. Disconnect the back up light switch (only for diagnostics) and see if you can now actuate reverse without blowing the fuse. If so, chase the short in the back up light wiring (often a chafed or burned wire).
Good luck.
hollywoodstang
1,095
Oct 31, 2006
  • Oct 31, 2006
I replace the fuse. and it pops soon as i put it in reverse.
i can't see anything wrong with anywires in the back up light system. everything looks fine. my top goes up and down and i am able to make signals and my airbag light goes away soon as i put new fuse in. but AS SOON AS I PUT THE GEAR IN REVERSE "POP!!" fuse blows!!! it's getting annoying. please help!!!
HISSIN50
34
129
Oct 31, 2006
  • Oct 31, 2006
I still stand by my above thoughts. There's power to the switch with the key on, and what changes is that when you put it in reverse, power is allowed to pass through the switch and go to the back of the car and back-up lights. The issue should be from the switch to the back up lights.
Good luck.
hollywoodstang
1,095
Oct 31, 2006
  • Oct 31, 2006
i disconnect the rear tail light connector and put in reverse. And fuse still blows!!! so what's next? i really need help with this.
thanks
hollywoodstang
1,095
Oct 31, 2006
  • Oct 31, 2006
so where is the back up light switch located at?
HISSIN50
34
129
Oct 31, 2006
  • Oct 31, 2006
On the side of the trans.
hollywoodstang
1,095
Oct 31, 2006
#10
  • Oct 31, 2006
  • #10
is it something i can change myself or do i have to take it to the dealership? and how much is the part?
thanks
HISSIN50
34
129
Oct 31, 2006
#11
  • Oct 31, 2006
  • #11
You first need to unplug the electrical connector to it and put the car in reverse and see if the fuse still blows. It should not.
Then trace wires to find the short. The switches occasionally crap out, but a short in the run of wiring is also quite likely. It just takes some time and visually going over things. A short finder with an audible alert can be helpful.
Good luck.
hollywoodstang
1,095
Oct 31, 2006
#12
  • Oct 31, 2006
  • #12
it turned out to be a back up light switch. i took it to ford to get it fixed. another $100 day. the switch itself costed me $55.22 so $40 dollar labor at the dealership isn't that bad i guess. plus they gave me a discount. if i were trying to fix it myself it would have took lot longer and i probably take the whole car apart to find the problem.
thank you for your help
HISSIN50
34
129
Oct 31, 2006
#13
  • Oct 31, 2006
  • #13
Glad to hear its fixed.
D
Speedo and tach dead
  • Davinrobinson1
  • Jul 19, 2026
1994 - 1995 Specific Tech Jul 26, 2026
fasterthangas
F
Electrical V8 swap no power to anything
  • Bullittsmith
  • Sep 12, 2026
1994 - 1995 Specific Tech Sep 15, 2026
Mcmahst
G
Help! Radio, door chime fuse keeps blowing.
  • goofyfoot53
  • Sep 9, 2025
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Sep 9, 2025
91AOD5.0LX
F
Fox 1988 GT Lumbar controls not working
  • Fcortes795
  • Mar 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 7, 2026
AeroCoupe
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
