Fusible Link burned up...need help!
87_LX_5.0
142
23
29
Uniontown, PA
How difficult is it to replace a fusible link? I had one burn up on me today in my 87 LX 5.0. The link connects to the selenoid and is yellow coming from the selenoid to the 16g fusible link. The wire coming out of the other side of the link appears to be black. I believe this is the link that controls the starter since I still have power to everything but the car will not start. When I turn the key I can hear the fuel pump run for a couple of seconds and all of my lights work. The wire burned completely through on the selenoid side of the link.
Any and all help/suggestions are appreciated!!:notnice:
Click on the diagram to enlarge it to full size
attachment.php
Fuse links come with a current rating just like fuses. A clue as to what current they are designed for is to look at the size wire they protect.
Choose the fuse according to the wire size.
Wire size current table:
18 gauge wire = 5-8 amps
16 gauge wire = 10-12 amps
14 gauge wire = 15-17 amps
12 gauge wire = 20-25 amps
10 gauge wire = 30-40 amps
8 gauge wire = 50-60 amps.
Fusible link colors
Link Gauge Color
20 Gauge Blue
18 Gauge Brown or Red
16 Gauge Black or Orange
14 Gauge Green
12 Gauge Gray
Keep in mind that the wire size in the chart is for the circuit itself, not the size of the fuse link. The packages of fuse link repair material you can get at the auto parts stores also will have a current rating on them.
See Ford Fuel Injection How To Solder Like a Pro for some excellent tips of soldering wires for best electrical performance.
Aircraft type circuit breakers are designed for low voltage DC applications and would be an excellent choice to replace fuse links. They come as a push/pull to reset button, and range from 1.5 amps to 60 amps and higher.
See Pilot Supplies, Avionics, and Homebuilt Aircraft Parts from Aircraft Spruce and Specialty Co. or http://www.wicksaircraft.com/catalogDetails.php or Home for circuit breakers and other items.
There is a store local to Orlando that does electronic surplus and has all kinds of circuit breakers. See index That's where I get most of my wiring supplies. There may be a similar type store in your area.
Thanks for the info. The wire actually burned out between where the four wires come out of the connection and the fuse link. Do I need to replace the entire connector from the solenoid and all four fuse links or is there a way to repair just the one?
The yellow wire comes off of the solenoid into a round rubber part and then the four separate fuse links come off of that.
Again, thanks for the info
Cut out the burned fuse link or wire and replace it. The yellow wire that connects the 4 links to the starter solenoid isn't a fuse link. You can replace it with standard 10 gauge wire from the auto parts store.
You will probably get to cut the rubber covered junction out to replace the damaged wire or fuse link. Strip the insulation off the cut ends and twist the stripped ends together to rejoin them. Be sure to solder the new wire or fuse link in place. See the link in my previous post to Ford Fuel Injection How To Solder Like a Pro for some excellent tips of soldering wires for best electrical performance.
Hmmm... can it be an epidemic?
I just had a 20GA link burn up on my 85 GT. Same place- starter relay switch (solenoid). Do you have a diagram for 85's?
How about availability? I've tried my local parts stores with no luck.
