gas gauge issues
  • Thread starter Thread starter 6Stang7
  • Start date Start date Jul 20, 2005
6Stang7
1,470
Livermore, CA
Jul 20, 2005
  • Jul 20, 2005
so my gas gauge never reads full. so i figured that the float in the tank had a leak or something. pull the sending unit out, and lift the arm all the way up and it still pegs out at about 3/4's of a tank. what gives? anyone know what the maz and min ohm reading on the sending unit should be?
latamud
791
Tampa, FL
Jul 21, 2005
  • Jul 21, 2005
10 and 72 Ohms one is min and one is max, can't remember which, try a search.
Max Power
1,774
St Paul
Jul 21, 2005
  • Jul 21, 2005
Could be the dash gauge itself. Does it go to full when you ground it with no resistance?
66newbie
84
  • Jul 21, 2005
Where does the needle sit when it's close to empty ? The only reason I ask is, my temp gauge goes well past "C" and then when it heats up, it never goes to where I think is normal. I was wondering if it would be possible to reset the position of the needle on a gauge myself.
F
ForceFed70
That's why they call it "dope"
4,818
BC Canada
Jul 21, 2005
  • Jul 21, 2005
Same thing happened to me when I installed a new sender.
I never did figure out the problem. Old sender seemed to work fine, but I figured since I was replacing the tank might as well do the sender at the same time.
Jester67
908
TN
Jul 21, 2005
  • Jul 21, 2005
73Ωs Empty / 8-12Ωs Full
6Stang7
1,470
Livermore, CA
Jul 21, 2005
  • Jul 21, 2005
mine reading around 76ohms empty and about 12-17ohms full. however, when i short the gas sending unit wire to ground, the gauge goes well pass full. i guess i'll just buy a new sending unit and hope for the best. anyone have any ideas on this one? i guess the 5 ohms is making that much of a difference.
68 fuel gauge maxes out at half
  • connella08
  • Sep 5, 2025
Classic Mustang Specific Tech Sep 8, 2025
connella08
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
F
Difference between 83-86 EFI and 87-97 gas tanks?
  • ForeverDrivin
  • Mar 30, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 30, 2026
ForeverDrivin
F
1970 Mach 1 Fuel Gauge Issues
  • 70 Mach
  • Jun 13, 2024
2K
Classic Mustang Specific Tech Sep 1, 2024
Mach1 Driver
M
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
