gas guage problem
  • Thread starter Thread starter johnnyboy1111
  • Start date Start date Oct 29, 2004
J
johnnyboy1111
84
  • Oct 29, 2004
is there anyway of getting a gas guage working again short of removing the tank ? filled tank and has been stuck on full for about 3 weeks .......thanks Johnny
The Shape
2,224
East ARKANSAS Delta
Oct 29, 2004
  • Oct 29, 2004
This a fairly common problem on fox bodies. Me and alot of other guys just reset the trip odometer each time we fill up and keep up with it that way.
D
Daggar
3,902
  • Oct 29, 2004
Anyone have or know of a good solution for installing an ACCURATE fuel quantity system on a Fox? Mine's never stuck on full but I'd be all for ripping that system apart and putting something reliable in there.
JimBowy
330
Downriver, Mi
Oct 29, 2004
  • Oct 29, 2004
My guage will always read full after putting just a few gallons in it. Is it the float that gets stuck (or what is the issue?) I'd be willing to spend some money for an accurate system! My mileage changes greatly with driving habbits, so thats not a very accurate way of doing things.
The Shape
2,224
East ARKANSAS Delta
Oct 29, 2004
  • Oct 29, 2004
From what I have been told the condition where the gauge stays stuck on full is caused by a "slosh sensor" on the back of the gauge cluster. It was originaly there to stop the needle on the fuel gauge from bouncing all over the place as you go around corners and up and down hills. But as they get old they malfunction and you are left with a gauge stuck on full. Actually out of all of the foxes I have been in or driven only my '93 4 banger has a working fuel gauge.
JimBowy
330
Downriver, Mi
Oct 29, 2004
  • Oct 29, 2004
I thought it might be the float getting stuck...
Anyhow, do you know where this sensor is or if its easy to replace? I'm planning on dropping the tank to change a pump this winter anyhow. If its easy to get at (and relatively cheap) I'd try swapping in a new one.
The Shape
2,224
East ARKANSAS Delta
Oct 29, 2004
  • Oct 29, 2004
Well the sensor is behind the dash cluster not in the tank. I am not sure if Ford even still sells them. Might have to hit a J/Y for one.
Boss_Mustang_69
34
BC, Canada
Oct 29, 2004
  • Oct 29, 2004
Would the gauge work if you detatched the sensor?
C
criticman
723
Rome, GA
Oct 29, 2004
  • Oct 29, 2004
Yeah...my gauge is AWFUL! I just want to have a working gauge of some sort...b/c yes, although I can keep track of the trip meter, driving habits change the mileage a lot...
Anyway...if someone has GOOD input with answers, please post. It seems like we all have similar problems without a good answer (short of that sensor which may or may not be available).
bmorrisj
449
Buena Park, CA
Oct 29, 2004
#10
  • Oct 29, 2004
  • #10
50resto has new fuel senders...
83-86 $89
87-93 $82
94-97 $76
Mustang Yawie
281
14
28
Rialto CA
Oct 29, 2004
#11
  • Oct 29, 2004
  • #11
if you detach the sensor it will still read full, so it wont help. I got one from the junkyard and it worked fine. in my case it always read empty.
J
jd351
163
Everett, WA
Oct 29, 2004
#12
  • Oct 29, 2004
  • #12
I believe this is the small circuit board on th back of the cluster... about 2"x2"?
It also has a circuit in it to regulate voltage to other gages if it is the one I am thinking of. I have replaced this when my temp gage and oil gage read wacky. Ford sells (or did) them, they are (or were) about $20. Sure fixed my high temp gage and low oil pressure gage, but never have had problem with the fuel gage, so I dont know if this is the same part.
My temp would read 1/4 up dwhen it was dead cold, and my oil pressure would never come up off the bottom of the gage, even though I tested it witha mech. gage and had good pressure.
J
jd351
163
Everett, WA
Oct 29, 2004
#13
  • Oct 29, 2004
  • #13
Just checked on-line at ford parts network, the part is still available, but it is $57.00 now. It is called a 'gage voltage regulator'. Should be able to buy at any ford parts dept. price may be better at dealer.
Boss_Mustang_69
34
BC, Canada
Oct 29, 2004
#14
  • Oct 29, 2004
  • #14
Ya, well i figure the money that involves fixing this stupid thing, its not even close to considering fixing it. I'll just keep watching my trip meter..
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
Engine Coolant boiling in hose?
  • Teen'93stang5.0
  • Jun 3, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
Mustang5L5
F
Difference between 83-86 EFI and 87-97 gas tanks?
  • ForeverDrivin
  • Mar 30, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 30, 2026
ForeverDrivin
F
H
Fuel starvation issues, 91 EFI to carb swap. Car dying after 1-3 gallons used. EFI tank, electric fuel pump, bypass regulator. Dual fed carb
  • hassler
  • Oct 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 12, 2025
nickyb
Fox Turn signal flasher keeps failing
  • keel
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2026
