Engine Gas in my oil
LOL... 70 year old fat man doesn't move so fast anymore..
Looked like it was easier to get to the fuel pump from the bottom as the serpentine belts make it difficult from the top... Remember this is a Mechanical pump....
Since I am going to prep the car for wherever I take the sub frame connector weld job, I thought I would wait until I got it back up on the Race ramps and do the fuel pump then... Got that done this AM. I hope to put a good week into this as its supposed to be a bit cooler this week in Sunny Florida...
I think that would take some torching and cutting and Fah breee katin.....
I do think I might take my die grinder and a cutting disc and cut where the ends dump up a bit with a different angle maybe??
Reactions: slow84lx
That would definitely help but if the tail pipes could be pulled up about an inch along the length of them and then the tips trimmed like you are talking g about it would look on point. And that is literally just my opinion which is worth about zilch in most instances.
I will look that over and see if there is room for that... Not a bad idea.....
I finally broke down and replaced the factory exhaust with the mandatory flow master cat back Super 44’s which I love - except inside the car ! I had to make one clean cut behind the exhaust because I’m working on jack stands. Anyway the metal is perfect, including the polished ends.
( pea shooters )
If you can use them PM me
I bet it would cost less to adjust those pipes on the car by a muffler shop then buy'n another set and installing.
come on fly the freak flag and buck the norm :kmcoff:
Everybody puts chrome/polished tips on their crap,
Reactions: limp
  • PlusOne
Reactions: General karthief
You need to get the gassy oil out ASAP or things like this will happen.......................
Later on as you start driving it and notice any loose sounding rocker arms or loose valvetrain components just know this is where the sound will b emminating from......
Good Luck and get yourself a wideband controller too as it will help keep your engine in tune...............
Reactions: limp
