Gas in the oil pan again... Fuel Pressure Question
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
93 5speed
66k
HCI
Gas is in the oil pan again. Car sputters and surges and pops. I'm guessing I blew the diaphram in the Adj Fuel Pressure Regulator because the last thing I did was jack the fuel pressure up to 55... There are a couple of spark plugs with thick black soot. Heh live and learn right?
My plan is to by another FPR, put on some 24lb injectors (already have a better pump installed), and change the plugs yet again.
I am thinking that I need to copy the 93 Cobra setup. Does anyone know what the fuel pressure was set at in a 93 Cobra? They cam with 24's if I recall.
Should I change the EEC too?
:shrug:
if you put 24's in without tuner or a calibrated MAF, I would think you are still going to run rich.
not if you run the cobra eec, it used a regular production maf with an eec programmed for the 24's, and the rest of the fuel system should be the same as lx/gt. as to whether you go that route or with a cal'd maf is up to you.
