Gas pedal acting screwy?
  • Thread starter Thread starter 91stangy
  • Start date Start date Jan 10, 2007
9
91stangy
116
  • Jan 10, 2007
I own an 87 5.0 fox (5 speed), and I decided to get on it a bit when a 03 Mustang dared me haha. Almost immediately after our little show my gas pedal started acting a bit funny. Now there is no best way to explain this, so I'm going to try. After all of that nonsense, and ever since... my pedal has had a huge response change, I would lay my foot on it, applying slim to no pressure on the pedal and my car would accelerate quite quickly. The pedal seems to be at the right height as it usually is, but it has a very small change of stiffness, it becomes a little too "loose." By pressing the whole pedal to the floor, it's loose for maybe a half inch? After that it feels as stiff as it should be, maybe a little stiffer? But nothing huge and drastic, just how much acceleration I have lol. Then about a minute later it will return to normal and I can rest my foot on the pedal without any acceleration. Then again it will return back to being a pest. As you would imagine when it decides to switch itself (or whatever it's doing) back to a more responsive touch it makes it hard for me to shift or even drive for that matter. I can't figure out what is happening; I don't even know what causes it to happen. I'm starting to believe that it only happens when I push the pedal a little harder, but still not sure because it doesn't happen all of the time.
I'm asking if anyone has any advice on what to check and how, I’m open to all suggestions. I just want to drive normal again haha.
If you have any questions about my story or what exactly happens, I'll be happy to try to expand a little more, to make it a bit clearer. Until then I'll be looking around trying to find the problem. Thank you all for your time and suggestions if you have them.
Mustang78
486
Aberdeen, WA
Jan 10, 2007
  • Jan 10, 2007
your TPS(throttle position sensor) could be worn and not contacting where it should..if it's cheap try replacing it
~Mark~
9
91stangy
116
  • Jan 10, 2007
Could that also be why within time, I'll have to adjust my idle to keep a steady charge in my car.
If it were that sensor, would it really mess with how my pedal feels? It does feel different, enough to notice the change.
MikeC
240
SLC, UT
Jan 10, 2007
  • Jan 10, 2007
Clean the inside of the TB and check that the return spring is not worn out or damaged.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Jan 10, 2007
  • Jan 10, 2007
sometimes the TB blade will close too far and stick in the bore of the TB
tording
164
Hampton, VA
Jan 11, 2007
  • Jan 11, 2007
Mine does this and causes the pedal to stick somtimes. Anyway to fix this? Is it just because its dirty and needs to be cleaned?
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Jan 11, 2007
  • Jan 11, 2007
could be dirty and needs to be cleaned.......Mine was because the stop screw was out a bit to far causing the blade to close more than it should and it was sticking in the bore of the throttle body. I opened the T/B valve a tad and then had to set idle....there is a good writeup on idle adjustment at www.50tech.com
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
What is this noise?!
  • squirrel0420
  • Jul 3, 2025
2005 - 2014 S-197 Mustang -General/Talk- Jul 4, 2025
horse sence
D
Resolved 1985 GT brake pedal problems
  • DienstXIV
  • Jun 19, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2025
DienstXIV
D
Engine Surging idle on start-up
  • keel
  • Aug 11, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
keel
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
