so i was driving home from school and layed it on the floor for a few seconds, when i let off to shift up it was redlining so i somehow immediatly knew what happened and turned the key off, reached down pulled the gas up and turned back on. the only problem is my tach needle ran itself into my steering column and is stuck there. 8k rpm ish. how do i get the dash apart to get the needle unstuck. what happens when i do, will it work again or do i have to reset it. i had to drive it with the needle stuck so is something stripped. i need help guys. thanks.
