  • 1994 - 1995 Specific Tech
Gas....
  • Thread starter Thread starter ddasilva99
  • Start date Start date Nov 9, 2004
1 of 2 Next Last
D
ddasilva99
17
London/Scarborough, Ontario, Canada
Nov 9, 2004
  • Nov 9, 2004
Hey there...its the newb again.
What type of gas does a 95' 5.0 V8 take? Prem mid or reg? Keep in mind I live in Canada if that makes a difference...
Thanks,
Derek
Venom351R
4,548
41
98
MAINE
Nov 9, 2004
  • Nov 9, 2004
you can run reg but mine always ran like crap on 87 octane. Even before my timming was bumped or before the blower I started to run 93 octane b/c the car ran so much better on it. If you can afford it run the more expensive stuff, if not just fill up w/ it every once in awhile, your car will thank you for it
95WhiteVenom
624
Alabama
Nov 9, 2004
  • Nov 9, 2004
be glad you don't own a cobra. That dang premium is expensive good thing my civic will be fixed soon its costly driving a gas hog over 100 miles a day.
ProKiller
3,064
15
78
PA
Nov 10, 2004
  • Nov 10, 2004
you can run regular. and be thankful that you can. Costs me like 25 bucks everytime i fill the tank. superchargers are great, but the gas sucks.
Venom351R
4,548
41
98
MAINE
Nov 10, 2004
  • Nov 10, 2004
your preaching to the quior on that one.
Scott_95GT
387
Sacramento
Nov 10, 2004
  • Nov 10, 2004
I always hear of people geting 93 octane at the pump. Where do you guys live? Here in California, 91 octane is premium and my stang runs so much better on the good stuff. I have also gotten my best mpg on premium. And now that I gave my timing a slight bump, premium is a must. The difference between premium and regular is only about an extra 2 bucks a fill up, which is less than ten bucks a month extra. Just put the good stuff in. Your car will thank you.
gcomfx.com
3,690
Republic, MO
Nov 10, 2004
  • Nov 10, 2004
I run 89 when not on the bottle.... and 91 or 93 when I am juicing. 93 isn't easy to find here either. Only a few stations have it.
I just bumped the timing back to 10* and am going back to the 75 shot. Trying to save a few bucks for more mods and to pay bills.
95WhiteVenom
624
Alabama
Nov 10, 2004
  • Nov 10, 2004
North Alabama only premium is 93 around here and 113 race gas at a few select stations.
blksn955.o
3,263
st.louis mo 314
Nov 10, 2004
  • Nov 10, 2004
Here in STL. there are a few stations that sell like 100 or so octain(it may be 98 though) but they are hard to find and you have to fill it into a gas can you cannot put it directly into the car. Speed shops sell all the good stuff from leaded to unleaded race gas. sunnoco-to-turbo blue........smells so good......
go.rei GT
267
Az
Nov 10, 2004
#10
  • Nov 10, 2004
  • #10
I don't know about other states, but right now in Az we're running our winter mixtures which add 10% ethanol. This raises the octane, without "raising the octane" so to speak. So, now the 89 I normally run to avoid pinging issues is now more like 91. So now I can bump the timing and enjoy for free, or run 87, save some money and retain my regular performance.
You guys should see if your states/counties do this...just a tip for fellow stangers.
I
igotyofire
774
Southern California
Nov 10, 2004
#11
  • Nov 10, 2004
  • #11
i dont know about you guys but my 95 cobra owners manuel says to run 87. Seeing as all of our cars cobra or GT came with the same compression stock, i belive thats what everyone should be running . I currently run 89 tho just because i dont want to risk it pinging...heh stock compression is 9.0:1 , that is low and we dont need to use high octane on our mildly stock motors , I dont care what you say!
HtownGT
544
Houston
Nov 10, 2004
#12
  • Nov 10, 2004
  • #12
my car runs great on 87, but a hell of a lot better with preminum
blksn955.o
3,263
st.louis mo 314
Nov 10, 2004
#13
  • Nov 10, 2004
  • #13
here in St. Louis we have 10% ethanol all the time.
go.rei GT
267
Az
Nov 10, 2004
#14
  • Nov 10, 2004
  • #14
Since you guys never switch (summer sucks here cause not only is it 110* but the gas gets MTBE) you might be getting a lower octane w/the ethanol. For example they add it to your 89 and Sell it as 91, ect. If not, you've got it pretty good there.
BlackVert
5,589
9
98
Bethesda, MD
Nov 10, 2004
#15
  • Nov 10, 2004
  • #15
i use regular (87 octane) gas.
MysteryMachine
1,835
Parkesburg, PA
Nov 10, 2004
#16
  • Nov 10, 2004
  • #16
Sometimes I get gas and boy does it stink
My car runs like crap on low grade so I use 93 all the time
HISSIN50
34
129
Nov 10, 2004
#17
  • Nov 10, 2004
  • #17
tell me about it (Tucson here). i run 15* in winter (under 90* ambient temps or so) and 10* in 110*.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Nov 10, 2004
#18
  • Nov 10, 2004
  • #18
The lower the octane you run, the better performance you will get. PERIOD
The ONLY reason you should run anything higher than 87 octane is if you... 1. Have a power adder (SC, Turbo, N20). 2. Have a high compression motor (over 10:1 , which neither the GT's or the cobra's have)
If you have detonation with 87 octane, you need to tune your car up. If you bump the timing, and you have to run 91 octane to remove detonation, then you are not gaining any power (add timing = +hp, but add octane = -hp, so it balances itself out).
Scott
HISSIN50
34
129
Nov 10, 2004
#19
  • Nov 10, 2004
  • #19
the higher the octane, the lower the volatility. so it takes longer to burn. if one has artificially high compression (deposits, etc), hot spots, etc, the car can experience detonation (or preignition from carbon).
higher octane when not necessary is detrimental. however if someone is pinging, cleaning chambers, backing timing down or running higher octane are ways to help it out.
this goes along with what Scott said. (going a bit more into the relationship between advancing timing vs using slower burning fuel).
blksn955.o
3,263
st.louis mo 314
Nov 10, 2004
#20
  • Nov 10, 2004
  • #20
I think it has to do with all the excess corn here in the midwest , I know the comp. are checked to make sure the rating is what the actual octane is so I dont know about the 89 as 91 thing. As far as MTBE well I noticed its in some of those octane boosters from what I have heard it sucks. I had a printout of how to make homemade race gas by adding things got preaty freaky.
Yes higher octane is not always good. You should run the octane your car needs. octane is the ability of the fuel to not burn or pre-ignite. Its heat tollerance (you can put a lit cigarette out in a gallon of open pump gas). You should always run the lowest octane you can without getting det. N/A.
1 of 2 Next Last
M
05 Mustang GT With Annoying P0463 Issue
  • Machbud
  • Oct 17, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Oct 24, 2026
manicmechanic007
G
Octane on the 5.0 Coyote
  • gray owl
  • May 17, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk May 27, 2026
Bullitt347
badge placement
  • 65er
  • Jun 8, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 8, 2026
65er
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
F
Difference between 83-86 EFI and 87-97 gas tanks?
  • ForeverDrivin
  • Mar 30, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 30, 2026
ForeverDrivin
F
