gasket help please
so i feel like a dumb ass, and i think i blew a head gasket but im not sure tho, so let me get to it ok. tonite i went to seafoam my moms saburbin with a 454 big block and it had a dead bat, well i used the stang to jump it but i i had no drive shaft and my heater hoses arnt hooked up i had some coolint in the rad tho, so i pushd the stand back to jump the chevy and it took some revs well alot to finaly get my moms car to start, the temp gage in car was'nt even at the half way point but there was water coming out the heater hose and it started to get hot and it smoked a bit maby from hiting the header idk, what do you guys think? also when i shut the car off you could the coolint bubbling inside the motor or rad, not sure what part. also the old 2.3 motor that was in it had a blown gasket and when started and shut off made the same bubling sound so its got me worried, ive never changed a head gasket before or pulled the intake heads so i dont know how hard it would be to change. this sucks thow im not even done with my swap and this **** happens my stupidity pisses me off somtimes. anyways thanks for reading my rant hope someone can help thanks in advance.
david:bang:
I doubt you blew a head gasket in such a short amount of time jumping a car. If it only got to a halfway I wouldn't worried about it. Just pressure test it and see if it leaks and also check the oil to see if it mixed. Even if it did it's not that big a deal especially if your doing a 5.0 swap. I would put new headgaskets on it anyway.
your rite bro im not going to take any chances at all im going to to just replace the head gaskets now how do i go about riping this bitch apart lol this will be a first for me and i dont got a torque wrench either i gues ill be picking one up here now
Cylinder head removal & replacement, all types of heads on a 5.0 Mustang
Plan on 3 days to do the job if you haven't done it before.
Day one gets the heads off in 4-6 hours. Remove the A/C compressor mount bolts and move the compressor out of the way. The A/C compressor swings out of the way without disconnecting any of the lines or losing any refrigerant.
Mark all the electrical, smog and vacuum lines with tags to help you remember where to re-connect them.
Day two gets all the gasket surfaces scraped off extra clean and the heads dropped off at the machine shop if you are going to have them reconditioned. Time here is another 4-6 hours. Whatever you do, don't skimp on cleaning the gasket surfaces. New gaskets need to seat against bare metal and not the residue left from the old gaskets in order to seal leak free. This is the most time consuming and tiresome part of the job. Look for little things that need to be replaced like the short hose from the thermostat hosing to the water pump, damaged vacuum lines and hose clamps that are rusted or broken. . Cut a piece of cardboard to fit the lifter valley and help catch all the crud scraped off the gasket surfaces.
Day three starts when you get the heads back from the machine shop. This is the time to pick up all the little odd pieces you found needing replacement on your day two inspection/cleanup. Plan on 6-8 hours to reinstall the heads and reconnect everything. Plan on an additional 2 hours to troubleshoot/adjust everything.
Now for some practical tips:
Plan on cutting the thermostat to water pump hose, or removing the thermostat housing. Also plan on removing the distributor to get clearance to remove the intake manifold. Remove #1 spark plug, stick your finger in the spark plug hole and crank. When your finger gets air moving past it, stop cranking. Turn the engine until the timing marks line up with the pointer. Make a scribe mark on the distributor base and engine block. Now you can pull the distributor out. When you re-install the distributor back in the engine, make sure you are still on TDC compression for #1 and then line up the scribe mark on the distributor and engine. You will be very close to where the engine was timed when you took out the distributor. Be sure to put a rag or cap in the block where you removed the distributor. It will save you trouble if something falls into the empty distributor hole.
You'll need new head bolts - get ARP bolts ($40) or studs ($93, maybe more). The ARP bolts have a radius under the heads. The washers that come with the bolts have a chamfer cut in them. The radius under the bolt head mates up with the chamfer on the washer. Fail to do this and the bolts will never torque down properly. All the bolts get antiseize under the bolt heads, and everything but the short head bolts get it on the threads. You need Teflon pipe dope or ARP sealant to coat the threads of the short head bolts. The short bolts go into the water jacket and will seep coolant if you don't use the sealant.
My favorite trick that saves time and effort is the stay in place gasket. Be sure that you scrape (don't use a wire brush) all the old gasket material off, then clean all the surfaces with acetone or MEK.
When the surfaces are clean, use weather strip adhesive on the head to manifold surface, and on the side of the gasket that mates to the head. Follow the instructions on the tube or can and when it gets tacky, press the gasket down on the head.
Clean the area where the rubber rails mount to the block in front and in the rear with more acetone or MEK and do the same trick with the weather strip adhesive that you did to the heads.
Coat the rubber seals and the gasket area around the water passages with lots of Blue Silicone gasket sealer and put it together. Bingo! No leaks and no gaskets that shifted out of place.
If you reuse the injectors from your old setup, a repair kit is available from most auto parts stores if needed. Coat the injector body "O" rings with oil before you use them and everything will slide back together.
For iron heads, clean the combustion chambers with a wire brush in an air or electric drill. I used a scraper for the pistons. I don't like to use the wire brush on pistons because it will remove metal very easily.
Change the oil once you get everything back together. Once the engine is up & running, run it for 1-2 hours and change the oil.
Tools: a good torque wrench is a must have item. A razor blade scraper that holds a single edge razor blade from Home Depot or Ace hardware is another handy thing. Get a Chilton or Haynes shop manual - you'll need it for the bolt torques and patterns. The intake manifold has an especially odd pattern. You'll need access to a timing light to set the timing after you re-stab the distributor.
Consumable parts:
Fuel injector seal kits with 2 O rings and a pintle cap (Borg-Warner P/N 274081) are available at Pep Boys auto parts.
Cost is about $2.74 per kit. The pintle caps fit either injectors with a pin sticking out the injector end or 4 with more tiny holes in the injector end. The following are listed at the Borg-Warner site ( http://www.borg-warner.com ) as being resellers of Borg-Warner parts:
http://www.partsplus.com/ or http://www.autovalue.com/ or http://www.pepboys.com/ or http://www.federatedautoparts.com/
Most of the links above have store locators for finding a store in your area.
Head gaskets
upper manifold gasket
lower manifold gasket set.
Exhaust manifold gasket set
Rocker cover gaskets - look for the rubber ones with the steel bushings - Summit has them
Short formed hose between thermostat hosing and intake manifold
6 ft 7/64" or 1/8" vacuum hose
2 ft 1/2" heater hose
1 1/2 ft 5/8" heater hose
Blue Silicone sealer
ARP antiseize or equal for the bolts
ARP thread sealer or Teflon pipe dope for the short bolts.
4 each 3/4" hose clamps (spare item in case the old ones are bad)
4 each 1/2" hose clamps (spare item)
Machine shop charges will vary - figure $275-$350 to have heads checked for cracks, cleaned, surfaced, valves ground, valve guides reconditioned, valve springs checked and bad springs replaced.
Consumable parts:
Parts Plus - Premium Auto Parts & Accessories or Auto Value / Bumper to Bumper Quality Parts & Service - Home of the Aftermarket Auto Parts Alliance Group or Tires, Auto Parts Stores, Brakes & Automotive Parts | Pep Boys or Federated Auto Parts - Automotive Aftermarket
Head gaskets
wow that is alot of work damn o well i gota learn some how ha well thanks for going into detal much apreciated bro i know i should send the heads off but ima skip on it its not worth the cash after the swaps done ima order a block and slowly build a motor and put a new trans also ima put new heads all that good stuff i just wanna dd it till im done with the new and swap it in will it be fine if i dont send the heads in
