  • 1994 - 1995 Specific Tech
Gaskets for h/c/i
  • Thread starter Thread starter 95Mustang302
  • Start date Start date Feb 2, 2006
9
95Mustang302
302
  • Feb 2, 2006
I'm almost done gathering parts for my h/c/i buildup. All of my main parts are trick flow, the heads the cam and the intake are all trickflow. I'm basically piecing the engine kit seperatly for cheaper.
I need to know what gaskets I should use with this N/A setup.
Would it be ok to use the fms/felpro gasket set like this one...
http://store.summitracing.com/defau...4294908282+4294924755+4294925237&autoview=sku
I know that I need the trickflow upper to lower gaskets, but other than that should everything work?
mustangramair
326
Iowa
Feb 2, 2006
  • Feb 2, 2006
I used felpro gaskets. My heads came with a packet that told which ones to get with the part number. I believe the intake to head gasket was a Felpro 1250. I would piece the set together, that is what i did. I had to get a larger header gasket because the exhuast ports were too big for the stock gasket. There were a couple of gaskets listed that you don't need, like rear main seal and the oil pan gasket.
95cobraguy
637
11
Concord, NC by way of LI, NY
Feb 2, 2006
  • Feb 2, 2006
that set looks like it has everything u need.
For Sale 1994 GT 5L Trickflow h/c/i Tremec TR3550 Saleen copy - $7000 (Ann Arbor, MI)
  • no_fox_given
  • Mar 21, 2019
9K
SN95 Mustangs For Sale (1994-04) Mar 21, 2019
no_fox_given
Old H/c/i Installation Explanation And Pics
  • FastDriver
  • Jan 26, 2018
2K
Fox 5.0 Mustang Tech Jan 27, 2018
FastDriver
Engine Making Sure I'm Not Missing Anything
  • smilts
  • Apr 28, 2013
1994 - 1995 Specific Tech May 1, 2013
smilts
Will a 347 work with stock H/C/I?
  • Zero Signal
  • Dec 7, 2010
6K
1994 - 1995 Specific Tech Jan 6, 2011
revhead347
Throttle Body Comparison
  • k00ksta
  • Feb 26, 2009
8K
1994 - 1995 Specific Tech Jul 5, 2009
wytstang
W
