gauge cluster lighting problem
  • Thread starter Thread starter mtlman22
  • Start date Start date May 10, 2007
M
mtlman22
89
NY
May 10, 2007
  • May 10, 2007
i am having an issue with my gauge cluster lights, they simply dont work. now, i have now power to the fuse for them,but if i jump the headlight switch i now have power at the fuse,but still no power to the cluster connecter(blue/red wire). the wiring diagrams i have arent to great in showing splice locations or connector locations to trace that wire to determine if it might be broken? anyone have any ideas or places i should also check?...by the way this is an a 68 stang.
J
JamesW
64
Central Texas
May 10, 2007
  • May 10, 2007
Have you verified that the instrument panel has good ground?
M
mtlman22
89
NY
May 11, 2007
  • May 11, 2007
well it does,but even it it didnt i still would have power at the connector
G
gjz30075
250
Roswell, Ga
May 11, 2007
  • May 11, 2007
Is it possible the lights are turned off? Rotate the light switch knob in either direction to possibly clear up corrosion on the rheostat.
M
mtlman22
89
NY
May 11, 2007
  • May 11, 2007
that was one of the first things i tried just to cover my basics
geostang351
946
Danb., CT
May 11, 2007
  • May 11, 2007
Are you sure you checked the right fuse. I just had this same problem. The fuse looked good but was blown. It was the fuse in the middle of the fuse block that sits alone.
What about the headlight switch itself is it the original?
M
mtlman22
89
NY
May 11, 2007
  • May 11, 2007
yea its that little fuse thats sits in the middle of the fuse box, and the light switch is old and no good anyway because i have no power to the fuse in the first place but if i disconnect the headlight switch i can jump the switch and then i now have power at that fuse but still no power to the cluster
geostang351
946
Danb., CT
May 11, 2007
  • May 11, 2007
DId you actually test the fuse? You'll have power to one side of the fuse but not the other if it's burnt. When you test power to the fuse are you testing both sides of the fuse?
M
mtlman22
89
NY
May 16, 2007
  • May 16, 2007
well i did some more testing and it turned out to be the fuse block itself, like i said before it had power going in but not out at that wire. the connector was very loose in the block itself and the pins that hold the fuse were also loose. thanks guys!
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
M
Need help!
  • Masonevans726
  • Dec 17, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 17, 2025
Masonevans726
M
Electrical No dash lights
  • slojoexxx
  • Dec 11, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Dec 11, 2025
slojoexxx
