  • 1994 - 1995 Specific Tech
Gauge Help...
  • Thread starter Thread starter maximos
  • Start date Start date Jun 22, 2007
maximos
188
Columbus, OH
Jun 22, 2007
  • Jun 22, 2007
So my tachometer started acting funny shortly after my T56 was installed. It would just get stuck sometimes and now has become much more frequent. Apparently this is a common problem and the solution is to have the entire unit replaced. I was told the speedometer and the tachometer are one single unit. Now the problem is that there is only one unit left in the United States and it is $308. Should I go with it or should I try a custom setup with autometer gauges or something like that? Anybody have a non-factory gauge setup? I'm not talking about overlays but the actual gauges themselves. Any pics of your setup would be great too (for inspiration). Thanks in advance.
go-stang5.0
2,244
Glenview,Il
Jun 22, 2007
  • Jun 22, 2007
No one really makes gauge clusters for these cars...Autometer makes them for the newer ones beaause the odometer settings are stored in the cpu or somewhere else. THe only thing in the cluster is the lcd readout of milage. So swithing gauge clusters on those cars is really easy and doesnt mess with the milage. YOu can get a used cluster from a yard and replace yours with that and report the milage change to whatever local office you need to. Or you can take yours apart and replace parts inside from the junkyard donor, or take apart the odo on the junk yard one and change it to your milage, etc.. THeres writeups on taking the thing apart...just look for them. But yea as far as aftermarket gauges I have no clue.
Also, the t56 has nothing to do with your tach readings so I dont see how that could be the cause. Unless you messed up the tach wire somehow during the install. I would look into that..it may not even be a gauge cluster issue at all. As far as where the wire runs...I dont know so you will have to find that out on your own.
Oh, also you could just get an aftermarket tach and be done with it that way .
As you can see, you have lots, and lots of options.
go-stang5.0
2,244
Glenview,Il
Jun 22, 2007
  • Jun 22, 2007
Would be nice tho to have a nice accurate tach and a 200mph speedo in the factory gauge cluster tho....I'm kinda interested in that too.
maximos
188
Columbus, OH
Jun 22, 2007
  • Jun 22, 2007
wasn't there something about an autometer bezel that fit our cars? it would be nice to have some nice and more accurate gauges for everything.
bmac50
123
Florida
Jun 22, 2007
  • Jun 22, 2007
http://autometer.com/cat_mountsdetail.aspx?vid=400&sid=0&mid=1&pg=1&mdl=17&gw=13
maximos
188
Columbus, OH
Jun 22, 2007
  • Jun 22, 2007
That's exactly what I was looking for. Question is now, what gauges to go with should I decide to follow through on this project? Ideas?
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
Paint and Body Cowl grill
  • Wayne Waldrep
  • Jul 13, 2022
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 14, 2022
Wayne Waldrep
A
1991 5.0 with HCI - started car, running for a few minutes, started pushing coolant into the overflow tank and then puking out from there. I'm lost
  • AmericanMuscle4.6GT
  • Oct 16, 2022
4K
Fox 5.0 Mustang Tech Nov 30, 2022
CAMTWO1070
