  • SN95 4.6L Mustang Tech
gauge install question
  • Thread starter Thread starter rustang04
  • Start date Start date Sep 28, 2004
rustang04
Banned
May 4, 2004
239
  • Sep 28, 2004
can someone save me some time w/ install of auto meter tach and a/f gauge?
02 signal wire color:
tach signal wire color and location:
showstopper2
425
New Bedford, Ma.
Sep 28, 2004
  • Sep 28, 2004
you need a tach adaptor to install the tach. I got mine from www. Ponyexpressperformance.com
it will convert the pcm signal into a reading the tach can understand.
1low03gt
20+ Year Stangneter
May 24, 2004
708
11
38
Cold Hell,Ontario,Canada!!
Sep 28, 2004
  • Sep 28, 2004
You'll need the tach adapter,to start with.
And this is what i got form a email reply from autometer ( i used there tach adapter part # 9117)....
Locate the large, square, 42 pin wire harness connector on the passenger side firewall. Look for pin #34, which is usually located towards the corner of the connector and is usually a solid red or red with a green stripe wire, (occasionally white with blue stripe). Cut this wire in half and wire in the tach adapter in between the two cut halves. The solid red of the adapter
will attach to the wire half that still has power when the key is on. The red with green stripe wire of the adapter will attach to the other half of the wire you just cut. This way the power to the coils flows through the adapter. Ground the black wire of the adapter and hook the gray wire to the green wire of the tachometer.
As for the air fuel ratio gauge....
There are two options for this hookup as well, again it's the left or right sensors. Locate the PCM, which is above or behind the passenger side kick panel. Look for the 104-pin connector. For the left sensor you will go to pin 87 which is a red wire with a black stripe. For the right sensor you will go to pin 60 which is a gray wire with a light blue stripe.
....Good luck
Fast02
239
  • Oct 21, 2004
A note...its the square box with all the wires going into it and a 10mm bolt going through the center. You DONT have to remove this bolt or even loosen it. There are four little clips 2 on each side that you can use your fingers to lift up a little on each side and pull the cap. You will see #34 on the row of wires closest to the firewall and to the right if your standing in front of the car. You can mount the tach adapter right to the firewall.
There are two red wires....I cut the wrong one first. DOH! Then I removed the plastic and looked at the numbers and low and behold ANOTHER red wire #34.
Thank you 1lowGt!
Great Information...
J
Fox Lost all gauge cluster function after Holley Terminator X install
  • Justin17383
  • Monday at 4:57 PM
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Yesterday at 8:05 PM
LILCBRA
A
A/F ratio gauge install questions.
  • AngryH58
  • Sep 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 22, 2026
C
4375 auto meter air/fuel gauge
  • Canadianfox
  • Jul 27, 2025
  • Digital Self-tuning Forum
Digital Self-tuning Forum Jul 27, 2025
Canadianfox
C
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
Fox Turn signal flasher keeps failing
  • keel
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2026
