You'll need the tach adapter,to start with.
And this is what i got form a email reply from autometer ( i used there tach adapter part # 9117)....
Locate the large, square, 42 pin wire harness connector on the passenger side firewall. Look for pin #34, which is usually located towards the corner of the connector and is usually a solid red or red with a green stripe wire, (occasionally white with blue stripe). Cut this wire in half and wire in the tach adapter in between the two cut halves. The solid red of the adapter
will attach to the wire half that still has power when the key is on. The red with green stripe wire of the adapter will attach to the other half of the wire you just cut. This way the power to the coils flows through the adapter. Ground the black wire of the adapter and hook the gray wire to the green wire of the tachometer.
As for the air fuel ratio gauge....
There are two options for this hookup as well, again it's the left or right sensors. Locate the PCM, which is above or behind the passenger side kick panel. Look for the 104-pin connector. For the left sensor you will go to pin 87 which is a red wire with a black stripe. For the right sensor you will go to pin 60 which is a gray wire with a light blue stripe.
....Good luck
