Thanks a lot for your reply.. After fooling around with it for a few more hours, the only unconnected thing I can find is the actuator solenoid that locs the shifter in gear.. lol.. nice, but still no help. It's a 95 Mustang. I also have another cluster from a salvage mustang and tried that temp/fuel pressure gauge assembly, still nothing. The funny thing is, the voltometer was acting up with the heater before I began to redo interior, but the temp/speedometer wouldn't work at all. lol, ee since I reinstalled everything, the speedometer works fine, and so does the temp guage, gas is just dead. The car runs a little groggy too, especially in like 4th on the freeway shaking and such, with pulsating brakes at high speed... I cleaned the AIC, replaced air filter, used MAF cleaner on the MAF...
The Car used to wait a few moments to shut off, but after I either loosened the screw on the throttle body to lower idle (which to my understanding isn't even the proper way to adjust the idle on a 3.8, all done by PCM?) it shuts off fine now.. I did the idle reset where you wait two minutes with accessories on and off after unplugging the IAC Harness.. runs a little better but still I am at a loss, lol. If it makes a difference, the engine cooling fane was hotwired to run anytime the ignition was on, which I disconnected because it is winter here in OH and the fan isn't really necessary (or so newbly assume) to keep the engine cool as the temperature guage appears to be working... also, after driving like over 50 MPH, the oil pressure gauge will fluctuate UNTIL a little acceleration is given OR if the gear is placed in N, and the clock will also randomly shut off....
Are there any pigtail connectors I may have missed during install in the actual interior? I had everything stripped including carpet to the bare metal.. Once again any input is greatly appreciated I have been working so hard on this car I have had it since I was 16 bought it for $500 and it has come so far from the day I bought it... Since last September I have probably put over 250 Hrs of my free time into this thing, a vast majority trying to understand and try things that dont wind up even working...
Sum up off problems:
Fuel pressure Gauge never moves off of "E"- It may be important to add I did remove the needle at one point, but I secured it as much as possible.
Voltometer fluctuates with AC/Heater Operatio (Oil Pressure will also fluctuate very minimally)
Oil Pressure Gauge ERRATIC after a highway drive during Idle, such as at a stop light, returning to steady nurmal with a slight acceleration or gear switch to Neutral.
Dash Clock will randomly turn on and off, never storing correct time.
Pulsating breaks (Only at High Speeds)
Vibrations at higher speeds when in what appears to be 4th gear...
lol I know its a lot but any input on any matter would really be such a blessing..
Thanks!
