Gauge Mod Help
  • Thread starter Thread starter CornerCarvin67
  • Start date Start date Feb 22, 2006
CornerCarvin67
246
  • Feb 22, 2006
Two questions:
First... I can't find anymore the write up on the gage pod modification for the 67/68's... can't recall if Reen did this or not. I can't afford a grand to buy his outright. So I'm gonna make a run at doing it myself. Can someone help me with that link?
Second.... who else had did this? Any big problems? How about the wiring? Did you have to buy specific gages to be compatible with the existing wiring? Thanks!!
68stang351
850
9
39
Savoy TX
Feb 22, 2006
  • Feb 22, 2006
Edbert did it, and has a good write up on his website. He helped me a lot on mine. Try shooting him a pm.
foghorn67
I'll save you the time and choke myself
1,532
Orange County, CA
Feb 22, 2006
  • Feb 22, 2006
CornerCarvin67 said:
Two questions:
2 5/8" fit perfectly but requires a bit of work. 2 1/16" fit okay but only requires washers to hold them in place.
the 5" monster gauges require some creativity.
The senders will use the same wiring harness, but you'll have to use the included gauge senders instead of the stockers. (buying the right fuel gauge will be the only one not requiring a replacement sender)
You'll also have to make your own wiring for ground, power and 12v lighting.
easy work, just takes forever.
12sec67
1,301
San Diego, Ca
Feb 22, 2006
  • Feb 22, 2006
if you have a recall on the tach then you will have some problems.
67CoupeDriva
165
South Carolina
Feb 27, 2006
  • Feb 27, 2006
^^^That sucker is idling a little high, isn't it?
steel1212
1,180
Frankfort, Ky
Feb 27, 2006
  • Feb 27, 2006
He has some wiring issues I think. I think when he turns it off it runs up to 9k lol.
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
J
  • JRC99
  • Apr 19, 2025
JRC99
J
98 GT PI Swapped Engine Fires, Dies Immediately NOT PATS
  • MMccPerformance
  • Dec 2, 2023
  • SN95 4.6L Mustang Tech
2K
SN95 4.6L Mustang Tech Dec 20, 2023
Yel2002GTAuto
Y
New daily driver help needed.....not a mustang but mustang drivetrain.
  • Wayne Waldrep
  • Jun 17, 2024
  • Other Auto Tech
  • 3 4 5
7K
Other Auto Tech Jul 28, 2024
manicmechanic007
