Gauges are being wierd!!
Well I put my motor back into my car not too long ago, and when I turn the key to give it power all my gauges on my speedo go to max and back, and then when I start the car they do the same thing, and go back to normal Idle RPM, does anyone know whats wrong with it?!?!?!
Thanks,
JT
Team801 said:
Same thing was happening on my 2001 GT a while back. It turned out that the postive cable wasn't as tight as it should be on the battery post. Just check all the power connections. Have you had the gauge cluster out recently? If so, just make sure the connectors in the back of the cluster are completely plugged in.
WES
