T TROJN007 New Member Apr 15, 2004 72 0 0 Greenwood IN Apr 27, 2004 #1 Apr 27, 2004 #1 I'm putting in a volt meter, water temp, and oil pressure gauges, anyone have any tips to help the installation along?
94GTLaserRC Squint as you approach, lest you be blinded by my 15 Year Member May 7, 2002 11,178 13 89 Ernan Says "here it comes... dushbag" Apr 27, 2004 #2 Apr 27, 2004 #2 Teflon the fittings, use the same power/dimmer/ground wires if possible to make it easier, use a Tee on the OP gauge so they both work...CHeck for leaks when all done! RC
