  • SN95 4.6L Mustang Tech
Gauges?
  • Thread starter Thread starter blk2003GT
  • Start date Start date Dec 15, 2006
blk2003GT
108
Las Cruces, NM
Dec 15, 2006
  • Dec 15, 2006
hey guys i have a question:
if i get a wideband air/fuel ratio gauge is it still advisable to get a fuel pressure gauge? i'm running a 100 wet shot and i also have a tune with the timing retarded and a little extra fuel on my xcalII.
R
Roger_4.6_96
1,209
Reno,NV
Dec 17, 2006
  • Dec 17, 2006
All a air fuel guage will do is monitor your air fuel ratio. If you get fuel pressure gauge it will monitor your fuel pressure.
sgarlic
3,085
Dec 17, 2006
  • Dec 17, 2006
I would.
D
Dragstr05
643
Stafford VA
Dec 17, 2006
  • Dec 17, 2006
The fuel pressure guage would certainly be good to have, but I certainly any change in fuel pressure will show up on the A/F guage, and regardless what the fuel pressure guage reads, if that wideband pegs lean, I'm letting off!
aleborjas
610
  • Dec 17, 2006
you can run more nitrous with the stock engine in my father's shop i've seen stock car with 150 wet shot just coolder plugs (motorcraft 22c)
T
thomas91169
I'd donkey punch my sister.
Aug 19, 2005
Modesto, CA
Dec 17, 2006
  • Dec 17, 2006
yes.
a wideband a/f gauge is a must on just about any modded car. why WOULDNT you want to be able to see your true a/f ratio in realtime?
and since you are nitrous, a fuel pressure gauge is also a very good thing.
also if you want a triple pillar setup, id throw in a EGT gauge as well. buddy of mine in his dsm was on the freeway when his EGT shot up, his a/f remained where it should be. pulled over, and found his water pump was done, and the water temp gauges are slow to react in those cars.
triggz
1,218
Gadsden, AL
Dec 17, 2006
  • Dec 17, 2006
I agree with thomas on the EGT gauge, I'd say its more important and accurate than an AFR gauge. The FP gauge is a good idea, but for as much as they cost you should get the EGT, assuming you already have a FP safety switch for the nitrous to do emergency monitoring on the pump in case it goes out halfway through a nitrous pass.
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
A
A/F ratio gauge install questions.
  • AngryH58
  • Sep 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 22, 2026
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
