gauging interest
jcagle
i have a 2000 trans am and a 2000 r6 yamaha sport bike asking 4800 on the ta and 4200 on the bike or trade for an older hot rod and a guy sent me an email wanting to trade heres the ad like to see what you guys think ...
1991 Mustang GT is in the process of being professionaly painted dark shadow gey from right under the windows up and black on the bottom. has Cobra rear bumber and wing, and cobra r cowl hood. Also has Centerline Convo-pro 15x4 and 15x8.5.
ENGINE
347ci,12:1 comp, pump gas
FRPP sportsman block
3.400 scat 4340 crank
scat 4340 5.4 rods
ross flat top 2618 forged pistons
romac aluminum balancer
comp custom hydr roller nitrous camshaft
FRPP lifters
comp pushrods
scorpion 1.7 aluminum roller rockers
AFR 225 heads with nitrous exh ports
edelbrock victor 5.0 intake ported to match heads
42lb injectors
75mm throttle body
76mm mass air
underdrive pulley
TRANS
NEW Lentech strip terminator AOD with every option except trans brake
lentech 9" race converter 4200 stall
IGNITION
MSD 6Al
MSD wires
NGK plugs
MSD coil
evrything else on the car is stock with the exception of 4.30 gears, KYB gas adjust shocks and struts, and eibach drag springs. everything works on the car except the a/c which i removed but still have it all if someone wanted to put it back on. has full grey interior and leather seats, the fronts are in pretty bad shape tho.
