GEAR DRIVE OR CHAIN DRIVE
  • Thread starter Thread starter josepi88
  • Start date Start date Feb 4, 2008
J
josepi88
  • Feb 4, 2008
JUST BOUGHT AN 89 LX 5.0L CONVERTABLE
THE ENGINE MAKES A WHINING SOUND, AND THE OWNER SAYS ITS CAUSE ITS GEAR DRIVEN NOT CHAIN, CAUSE THEY CHANGED IT
DOES THAT ,MAKE SENSE
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Feb 4, 2008
  • Feb 4, 2008
Yes, a gear drive will make a wine, but so will a power steering pump.
347 Pony
36
Sterling, VA
Feb 4, 2008
  • Feb 4, 2008
Depending on the gear drive it will definatley make a whineing sound
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Feb 4, 2008
  • Feb 4, 2008
could sound like a blower actually. pain in the but if u ask me. i like a chain myself.
A
ARTTII
272
Detroit, MI
Feb 4, 2008
  • Feb 4, 2008
does it have a rachet sound to it? I had a pete jackson NOISY gear drive for a few thousand miles, could not stand it and had to rip it out for a double roller. It gets REALLY high pitched when on the highway/or high RPMS and rings the heck out of your ears...
It was cool to roll into a car show with it, about 4500 rpms in 1st, people all turn and look. can't pop the hood though, no blower to back up the sound!!! not cool, that is another reason i got rid of it, don't know what the PO was thinking...
J
josepi88
  • Feb 5, 2008
is it any better to have this?
can i make it any quieter?
samickguy15
404
Delavan, IL
Feb 5, 2008
  • Feb 5, 2008
Gear drives deliver more accuracy but are inherently noisey.
Is it better? To some degree, but not really necessary for 99% of the motors people here build.
Can you make it quiter? No. The noise you get come from the gear mesh. The only way it would be quiter is if it was a herring bone style gear (very pricey to make) or a helical cut gear which would induce axial loading on the crank and cam. So again, No.
JUCD 5.0
107
Belleville, Illinois (ST.Louis area)
Feb 7, 2008
  • Feb 7, 2008
I also plan on installing a gear drive and was wondering what a good solid brand to get would be? Any suggestions? I'm not looking to break spend alot but a decent one for sure. Thanks
Wallzy
128
Orlando, FL
Feb 7, 2008
  • Feb 7, 2008
That is not exactly true compared to some of the new timing device designs; there has been an abundant of papers published regarding this topic. To sum it up without diving into too much detail, NASCAR uses belt drives for a reason.
Walz
ironmedic
1,361
Puyallup, WA
Feb 7, 2008
#10
  • Feb 7, 2008
  • #10
i used to have a gear drive set. forgot the maker on it. it was so loud i could not hear my exhaust at low rpm's. i know if the gears come out of sync, the noise gets worse (or something like that). i could not stand the gear drive noise. i was too lazy to put a chain back on
7-UP BILL
885
My other car is a Firetruck
Feb 8, 2008
#11
  • Feb 8, 2008
  • #11
I have an Edelbrock gear drive and yes, you can hear it, but it's not obnoxiously noisy. While I have a Vortech also, it is not overpowering. I actually have had people say they like it 'cause it doesn't sound like any other Mustang they've ever heard. To install a gear drive you must remove the chain oiler on the front cover, so if you decide you don't like it, you'll need a new cover. BTW it's been in motor for 13 yrs with no problems.
G
gofugyourselv
#12
  • Nov 4, 2008
  • #12
How much are these gear drives like a Pete Jackson and does anyone have a sound clip on just how noisy they are?
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
Idles great, but stumbles when driving
  • Stang9050
  • Oct 15, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 8, 2025
Mcmahst
D
Rockers, lash adjusters and timing: help with parts (4.6 2v)
  • dvigAtel
  • Nov 1, 2025
  • Other Auto Tech
Other Auto Tech Nov 1, 2025
dvigAtel
D
Drivetrain Fox Power Loss While In Gear
  • J_5.0_VERT
  • Dec 17, 2024
2K
Fox 5.0 Mustang Tech Dec 31, 2024
J_5.0_VERT
