Gear Drives!!!
  • Thread starter Thread starter Reddevil91
  • Start date Start date Jan 27, 2018
Reddevil91
1,630
773
163
Jan 27, 2018
  • Jan 27, 2018
Ok so my car still runs a gear drive instead of timing chain. I liked the whiny noise it made back in the day. So as I am starting to make progress on parts, I’m starting to wonder are these still relevant. I mean I remeber when c&l mass airs was a big name and now they are considered junk, and I guess obsolete since I don’t really see their name anywhere. That just went off track sorry, Point is are gear drives still decent or should I swap to a timing chain now that my motor will be making more power once all is said and done!
cleanLX
976
537
144
Jan 27, 2018
  • Jan 27, 2018
I was always told that gear drives were never relevant... something to do with harmonics.
C'n'L got a bad rap thru internet myths.
First thing my tuner asked was "you don't have a ProM do you?" when I told him no, have a C'n'L I was waiting for the lecture and was quite surprised when he was happy and went into a discussion about how the C'n'L is so much better to work with due to no 3rd party electronics. Went on to explain it in detail, but, over my head. He said if it's not Ford or C'n'L he wont touch it... Now, I'm not a tuner, but, cars come from all over the country to this guy, and he's got a bunch of 2000+hp vette's from filthy rich Saudis in his shop, so, I'm guessing he knows something.
CarMichael Angelo
8,909
234
Birmingham, al
Jan 27, 2018
  • Jan 27, 2018
Gear drives were relevant in the 60's and 70's when timing chains were crap. The old chains were prone to stretching, and when it came to advancing/retarding the cam, required that you drill the big gear, and use a offset bushing to move the cam one way, or the other. A real pain in the ass. Now there are billet sprockets , with multi-indexed crank gears, that make degreeing the cam way easier. High strength, true roller, double row timing chains that don't stretch at high rpm and allow cam timing to change with it.
Gear drives have always had a bad rap,...as they induce bad harmonics as a side effect. They do this because a chain acts as a damper to isolate those bad harmonics.
Now, for all but the more serious effort race cars, a chain will be more than sufficient. A more dedicated effort race build usually gets a belt.
srtthis
the guy doing it does every local racers rear end
5,129
1,666
204
Maryland
Jan 29, 2018
  • Jan 29, 2018
RCD is the only gear drive id even think about
D
Brake & Suspension Rebuild
  • DuluthFoxbody
  • Nov 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Saturday at 8:51 AM
Rdub6
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
W
Megasquirt base tune for 94 5.0
  • wrx757
  • Mar 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 6, 2026
wrx757
W
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
  • Mindseye007
  • Aug 16, 2026
Mindseye007
