  • SN95 4.6L Mustang Tech
Gear install kit question
  • Thread starter Thread starter DarkHorse164
  • Start date Start date Jan 9, 2004
D
DarkHorse164
319
Port Charlotte, FL
Jan 9, 2004
  • Jan 9, 2004
When changing the gears, is it necessary to use an installation kit? On some sites I see that there are up to 3 different install kits; each with a couple 'extra' parts. Any idea which would be needed or how to determine?
I've got my gears and want to get them installed. I just don't want to make the trip to the installer just to find out I don't have what I need.
Also, I do not plan to go the speedcal route. I'm looking into an adaptive tune through T&J. Can the car be driven with the new gears installed on the stock computer program without problems or damage? I'm aware the mileage/speedo will be off...but anything else to look at? OR can I have my computer flashed for the new gears and tune PRIOR to gear install?
forpit2000gt
2,490
Columbia, SC
Jan 9, 2004
  • Jan 9, 2004
depending on mileage , you may want to get new carrier bearings. You will need 1 bottle of friction modifier and gear oil. There is a FRPP set of gears that comes with pinion nut, crush sleeve and shims. If purchased together or seperately , you will pay about $ 180.00 for the gears and necessary install kit. I would get a new pinion bearing as well. The carrier bearings are up to you and what the installer reccomends. the highest price install kit includes everything + axle bearings I think. Total for gears and install should be around $ 500.00.
9
97rmcobra
118
Milford,MA
Jan 9, 2004
  • Jan 9, 2004
Depends on what gear set you buy. Ford Racing comes with pinion shims, crush collar, and pinion nut. Also depends on how many miles you have on the car. So if low miles and you don't need carrier shims and bearings look good you could just get away with the Ford set and a cover gasket or RTV. But I would buy a Kit or make sure you have, Pinion Nut, Pinion Seal, Pinion bearings/race, Pinion shims, carrier shims, ring gear bolts, marking compound, Loctite, cover gasket, Friction additive, and gear oil. I am rebuilding my rear-end now and I only have 35000 miles on the car so if the carrier bearings look good I am leaving them on, they come in the kit too. You could also need axle bearings and seals but I am not replacing them do to low miles and inspection. I would recommend replacing the pinion bearings/race with any new gear set. Nation Drivetrain had the lowest price master set $79. I just bought it and have bought there kit before. They have everything except Friction additive and gear oil in the kit. www.nationaldrivetrain.com
forpit2000gt
2,490
Columbia, SC
Jan 9, 2004
  • Jan 9, 2004
http://www.nationaldrivetrain.com/
forgot to add this, glad someone else has used them. They are a great company and I have seen gears from them go into many 4x4 as well as 8 sec drag cars with no problem. The gears come with a sheet showing the proper backlash setting for the gear set you purchase.
D
DarkHorse164
319
Port Charlotte, FL
Jan 9, 2004
  • Jan 9, 2004
Ok. My GT has 17300 miles on it right now, with the last 2000+ miles being kinda harsh (bought it used w/ 15K. Orig. owner was 40ish and she only drove it up to 70 mph when on the highway-personal friend, so I know the history). By harsh, I mean LOTS of burn outs and high RPM launches at times with 315/35 rear tires.
With that said, I found a place called Diversified Products Marketing (i think) that has the Ford Racing gears someone mentioned for $139 plus $16 to ship. Their web address is www.BuyFordRacing.com or www.BuyFordMotorsport.com. While I already have the gears, it's the install kit I'm trying to determine the need for. Anyone ever use this source? Thanks for the details, BTW!
D
DarkHorse164
319
Port Charlotte, FL
Jan 9, 2004
  • Jan 9, 2004
gear recalibration ???'s
Can anyone help with this question?
R
Roller406BU
37
Elizabethtown, Ky
Jan 9, 2004
  • Jan 9, 2004
My carrier bearings were shot on my gt. My car has 36,000 miles on it just to give you an idea when i changed gears to 4.30's this month...
3.27-4.30
XTONKAX
619
UT
Jan 9, 2004
  • Jan 9, 2004
Now see, my bearings were all peachy at that mileage. It was when trying to get them off that we broke them and pieces went flying everywhere! Glad I had them for that reason alone!
forpit2000gt
2,490
Columbia, SC
Jan 10, 2004
  • Jan 10, 2004
there is a tool t oremove the bearings without messing them up.
If you are going to drive it like you have lately, do what I did. I installed a new carier with 31 spline and Strange 31 spline axles. Install the gears with new carrier bearings and don't worry about your rearend.
menasci
640
Chandler, AZ
Jan 11, 2004
#10
  • Jan 11, 2004
  • #10
I ordered the cheaper kit and then ordered the Pinion bearings and braces.
Didn't have to be changed but I figured what the hell.
It's a good thing I did though, 'cause I couldn't remove the pinion bearing from the old pinion, so I had to chizzle it off.
The reason for that was to check the size of the spacer on the original pinion.
TriBlkCobra
318
Dallas, TX
Jan 11, 2004
#11
  • Jan 11, 2004
  • #11
Dont sweat it. Only thing off will be speedometer and odometer. Thats it.
G
gsixl
74
Kansas
Jan 11, 2004
#12
  • Jan 11, 2004
  • #12
I purchased the kit when I did my install. Didn't need it so sent it back. I used FRPP gears and they went in fine with the original shims. You will need a dial indicator to check backlash and grease to check tooth alignment. I might have been lucky. Also do proper breakin of new gears. They have been in for a year with no noise or whine.
D
DarkHorse164
319
Port Charlotte, FL
Jan 12, 2004
#13
  • Jan 12, 2004
  • #13
OUTSTANDING!!!
Thanks for the help
Drivetrain How much resistance, if any at all, is normal on a new 1st gear and synchro on a WC T5 transmission?
  • sleep-e
  • Jan 21, 2026
Fox 5.0 Mustang Tech Jan 22, 2026
sleep-e
A
Procharger install/prep questions
  • ahratrew
  • Nov 22, 2025
SN95 4.6L Mustang Tech Nov 26, 2025
Salvage/rebuilt title question
  • djj62478
  • Oct 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 2, 2026
DadLife0724
  • dan50
  • Jul 18, 2026
dan50
W
I need a 1997 Mustang PATS A expert!
  • Wolfdogg
  • Oct 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 5, 2026
