Gear OIL
  • Thread starter Thread starter PhLoBuS
  • Start date Start date Sep 15, 2004
PhLoBuS
473
Beverly, MA
Sep 15, 2004
  • Sep 15, 2004
What gear oil would you guys recommend? I am going with a synthetic brand. Royal Purple, Mobil 1, Valvoline? let me know getting new gears installed tomorrow also it takes 3 quarts right?
giddyup306
3,041
Sep 15, 2004
  • Sep 15, 2004
Redline is good stuff. I highly recomend it. 3 quarts will be enough.
88stangmangt
2,332
Stafford,VA
Sep 15, 2004
  • Sep 15, 2004
i would only consider royal purple or amsoil........2.5 it should hold......
C
Copperstang87
163
Thunder Bay, Ont
Sep 15, 2004
  • Sep 15, 2004
When changing your diff/gear oil do you hafta use an additive?
R
ratrapp
510
buena vista,va
Sep 15, 2004
  • Sep 15, 2004
i've run royalpurple and redline both.there both good lubricants.it should take around 2 quarts.some say they have the modifier already in it but i add some to be on the safe side.
giddyup306
3,041
Sep 15, 2004
  • Sep 15, 2004
When your talking about adding a full synthetic you don't need a stabilizer. As mentioned most rear end oils already have it in it.
maverick0716
3,924
Chilliwack, BC, Canada
Sep 15, 2004
  • Sep 15, 2004
I run Redline and it's good stuff. It already has the friction modifier in it. I bought a bottle of it just in case but decided not to put it in. It works perfectly with no chattering.
HISSIN50
34
129
Sep 16, 2004
  • Sep 16, 2004
any of the name brand synthetics should be just great. just depends upon what you can get locally or quickly.
89MustangGX
I have nothing productive to add!
Jul 3, 2001
10,262
Mill Creek, WA
Sep 18, 2004
  • Sep 18, 2004
It depends on the oil. If it does not specifically say it does, it's a pretty safe bet it doesn't. Better to know ahead of time then be surprised later.
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Sep 18, 2004
#10
  • Sep 18, 2004
  • #10
I just run the Ford stuff with friction modifier in mine. Ones just as good as the other.
Oil choice for after break in period.
  • Sask84gt
  • Feb 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 14, 2026
Praetorious
P
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
2001 v6 New compressor issue
  • badmech
  • Apr 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 30, 2026
badmech
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
