Gear Ratio Question
  • Thread starter Thread starter black06pony
  • Start date Start date Feb 6, 2011
black06pony
  • Feb 6, 2011
I'm a newbie to engines and stuff but I'm trying to learn. My GT has a 3:31 Rear Axle Ratio. I have seen options for a 3:55 and 3:73. Several shops have said I could put a 3:73 Gear ratio in it and it would run faster. My 1st question is, what do these numbers mean? My 2nd question is, would a 3:73 work in a 06 GT Convertible? I have been on Ford's website and configured a couple of new GTs. The convertibles are always ONLY available with a 3:3I, even with a Shelby.
SpartaPerformance
2,517
61
89
Long Island NY
Feb 6, 2011
  • Feb 6, 2011
The gear ratio is how many revolutions the rear wheel have to the drive shaft, so 3.31 turns compared to 3.73 turns. The vehicle also accelerates quicker because torque to wheels is multiplied by a larger number. For example
300lb ft of torque * 3.31 = 993
300lb-ft of torque * 3.73 = 1119
mbuckcoyote
86
Portand, Or.
Feb 6, 2011
  • Feb 6, 2011
While that's an interesting take on gear ratios, the more common explaination is: how many teeth on the pinion gear there are as opposed to the ring gear. for example: 3.73= 11 teeth on pinion to 41 teeth on ring. 3.31 would be something like 10 teeth on the pinion to 33 on the ring. That's not completely correct but, close on this last one. The higher the number on the ratio (3.73, 4.11, etc.) the quicker the acceleration. But, will cost in top speed. The inverse is true for lower gears.
black06pony
  • Feb 6, 2011
Thanks! I think I understand. I just want to feel a quicker jump when I punch it. I'm not racing or anything, so top speed probably doesn't matter as much for me. I think I may have reached 100mph in this thing 1 time before I backed off of it.
j_lutter31
79
Central South Dakota
Feb 6, 2011
  • Feb 6, 2011
Another viewpoint.....
Say you have your 3.31 gears in your car. Maybe you have thought about upgrading to 3.73's or 4.10's. Well the higher you go with your ratio, the higher your rpm will be at any given speed.
For example, now at 70 mph you might be turning 2000 rpm, with the 4.10's it might be closer to 2400. Which will slightly hurt your fuel economy on the highway. Something to think about, some people will say it doesn't affect it enough to matter, some say otherwise....
D
demea
15
Warminster, PA
Feb 7, 2011
  • Feb 7, 2011
I think we should know if you are 5sp or auto?
4.10's for auto and 3.73's for 5sp is generally what people are running unless you plan on going SC, then the general consensus is to stay @ 3.73 for an auto.
My auto 06 vert GT has Ford Racing 4.10's and is 2500 @ 70mph fyi.
Gas mileage is down by about 15-20 miles per tank, but the fun factor is up 1000%
Especially with a custom tune and CAI, that all you really need in these cars.
black06pony
  • Feb 8, 2011
I have an automatic but it's convertible. I don't know why a convertible should matter, but I've noticed that Ford doesn't put anything except a 3.31 in the convertibles. You can't even order them with anything else. Looks like they do it that way for the Shelby convertible too. I can't figure out why.
ct07gt
377
  • Feb 9, 2011
They probably assume that performance is a lower priority to people buying convertibles. They might have been trying to keep the CAFE number up a little by keeping the convertibles' mileage up with the 3.31. There is no difference in the rear end between a coupe and convertible, both use the 8.8" rear. Only the V6 had the weaker rear end. You can use any ratio made for the GT.
M
marktexaf
York, PA
Feb 10, 2011
  • Feb 10, 2011
Related Question
I would like to piggyback on this question. I bought my '08 GT used from a dealer and there were some mods done to it which I'm still trying to figure out. One that I suspect is the gears. Currently when I'm going 60 mph per the speedo, my GPS (two different ones) showed that I was going 70 mph. During a visit for scheduled MX, I asked the dealer to check on it. They said the wheels/tires are the original diameter. They said to find out for sure, they would have to take the diff apart. Question, with this info, do you think the gears were changed and what ratio do I have now? Looks like there is about a 10% difference with the speedo registering slower than the actual speed.
ct07gt
377
#10
  • Feb 10, 2011
  • #10
That would be an unusual change to a taller ratio, I have not heard of anyone making that switch. We would have to know the tire size and RPM at a given speed to get the ratio for you.
M
marktexaf
York, PA
Feb 12, 2011
#11
  • Feb 12, 2011
  • #11
Numbers
Here's the numbers on two separate runs..
Tire size= 235 x 50 x 18 (Ht 27.25)
Run 1:
RPM 2K
Speedo 61 Mph
GPS 52 Mph
Run 2:
RPM 2.3K
Speedo 75 Mph
GPS 65 Mph
ct07gt
377
#12
  • Feb 14, 2011
  • #12
Assuming you have a manual transmission and the speedometer is correct, it sounds like you have a 3.73 according to this calculator. JawsGear.com
You have a .68 transmission ratio in 5th. If the GPS is correct, then you might have a 4.10 rear end.
L
lokstag1
36
#13
  • Mar 26, 2011
  • #13
put car in neutral, jack up rear end. have a buddy hold one wheel. slowly rotate the other while paying attention to the drive shaft. Count the revolutions of your drive shaft to determine the gear ratio in your pumpkin. This will be very accurate and eliminate any guess work.
Cory281
240
Mar 27, 2011
#14
  • Mar 27, 2011
  • #14
If you want your car to feel faster and pull you back in the seat, get a tuner and CAI. They are around $550, but they make a big difference and is a lot easier to do then gears. American Muscle has some good CAI/programer combos.
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
Drivetrain 5th Gear Ratio
  • PonyGTrider
  • Dec 8, 2025
2K
Fox 5.0 Mustang Tech Dec 31, 2025
Qtrhrse23
D
96 get convertible-sell or part out?
  • DTCstang
  • May 17, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? May 18, 2026
nickyb
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Oct 12, 2026
limp
Drivetrain How much resistance, if any at all, is normal on a new 1st gear and synchro on a WC T5 transmission?
  • sleep-e
  • Jan 21, 2026
Fox 5.0 Mustang Tech Jan 22, 2026
sleep-e
