gear setting... pinion depth...HELP!!!
  • Thread starter Thread starter Fox_84
  • Start date Start date May 14, 2006
Fox_84
143
  • May 14, 2006
I am installing all new rear end components and can not find anyone locally that knows how, so I guess I am stuck doing it myself. I am putting all new parts and need some help on the pinion depth, preload, and backlash. ANY HELP AT ALL???
Grn92LX
Fidanza Man!
6,819
64
129
New York
May 14, 2006
  • May 14, 2006
http://www.angelfire.com/theforce/5ohcpa/cpa5ohtech001.htm
http://www.superstallions.com/tech/drive/gears/gears.html
Good luck. This isn't a job for the faint off heart if you have no idea what you're doing.
Myself and a buddy just did this not too long ago. He knew what he was doing and had the tools, I was just helping out.
What gears are you putting in? You'll have to grind the crosspin on the differential for 4.10 + gears. I did 4.30's in my car.
dragnazz5.0
My "0" key d0esn't w0rk, s0 I have t0 use the zer0
Nov 19, 2005
815
mooresville, nc
May 14, 2006
  • May 14, 2006
whats up with everyone getting new gears? is this just the time of year that everyone decides to get them?
BadAndy
766
Ohio
May 14, 2006
  • May 14, 2006
you have to check the depth before you dissasamble, I wrote mine down 2.532 and I [think] the back lash is 8 tho
Fox_84
143
  • May 14, 2006
I am putting in 3.73 gears and I have already disassembled and did not measure the stock pinion depth. Oops, where do I go from here?
Joe P.
56
Syracuse
May 14, 2006
  • May 14, 2006
Measure your original pinion shim and pinion together. This is the total measurement you need to shoot for with your new pinion to get to the original depth. Measure your new pinion and select the proper shim that puts you closest to your original measurement. This method should get you by if you are using Ford gears.
mattmcdan
176
Okeechobee, Florida
May 15, 2006
  • May 15, 2006
I just changed my gears today, I used the top link posted by Grn92lx, It was the most helpful because he didn't use any special tools, just run off the mill everyday hand tools.
K
Drivetrain '87 5.0 Installing New Ring Gear and Pinion - Pattern Questions
  • karhoot
  • Apr 23, 2026
Fox 5.0 Mustang Tech May 9, 2026
Mindseye007
Engine Starter ring gear depth. 3/8 or 3/4 inch?
  • 92Rustang
  • Aug 4, 2025
Fox 5.0 Mustang Tech Aug 22, 2025
Rcdgl
R
O
8.8 Pinion Nut Leak
  • OX1
  • Jan 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 5, 2026
OX1
O
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
