gear setting... pinion depth...HELP!!!
Fox_84
143
I am installing all new rear end components and can not find anyone locally that knows how, so I guess I am stuck doing it myself. I am putting all new parts and need some help on the pinion depth, preload, and backlash. ANY HELP AT ALL???
Measure your original pinion shim and pinion together. This is the total measurement you need to shoot for with your new pinion to get to the original depth. Measure your new pinion and select the proper shim that puts you closest to your original measurement. This method should get you by if you are using Ford gears.
