Gear
  • Thread starter Thread starter BAD67FUN
  • Start date Start date Feb 27, 2004
BAD67FUN
589
Wisconsin
Feb 27, 2004
  • Feb 27, 2004
Man, I just can't make up my mind. Maybe I'm PMSing. I took about an hour to read thru posts on gears and I still am nit-picking on whether to go with the 3.55 or the 3.80. I know they're close, but I can only pick one. I'm going to be stuck with my C4 at least another 2 to 3 years. My rubber in back is 275-40 (25.6" tall). The car is strictly a toy. Hardly any freeway. And I'm planning on autocrossing again. Well, which one... and why? Thanks.
Edbert
3,548
32
109
Austin TX
Feb 27, 2004
  • Feb 27, 2004
Check this out...
http://www.edbert.net/rpm_chart.htm
Use the "3rd" gear portion for C4, the "4th" is for the AOD (duh!).
BAD67FUN
589
Wisconsin
Feb 27, 2004
  • Feb 27, 2004
I got all that from a different calculator...
I'm just bored today and looking for opinions though.
ratio411
3,870
73
109
Pensacola FL
Feb 27, 2004
  • Feb 27, 2004
Your sig tells very little about your engine combo.
It doesn't make much difference since those gears are so close, but I could give reasons one way or another if I knew more about your cam and intake.
As it stands, I lean 3.80.
Reason being that the auto tranny has a fairly high first gear ratio. If you had a manual tranny I would lean to the 3.55.
Either gear you choose will seem like a huge difference from what you have now. If you switched a 3.55 for a 3.80, or vice-versa, you would probably not see a noticeable difference.
I did work under the assumption that your car is a small block, then judging weight, tire, intended use, and tranny... I like the 3.80.
Dave
BAD67FUN
589
Wisconsin
Feb 27, 2004
  • Feb 27, 2004
Thanks Dave. I leave out the specific engine detail because that will all change eventually. The only thing I can assure anyone of is that it will be a small block.
HistoricMustang
2,359
Confederate States of America
Feb 27, 2004
  • Feb 27, 2004
3.73 - 3.80 is fine for your situation.
HistoricMustang
www.historicmustang.com
T
Drivetrain Can’t identify correct speedometer gear
  • townethug
  • Jul 12, 2025
Fox 5.0 Mustang Tech Jul 21, 2025
FastDriver
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
Progress Thread The Mach Returns - Update/build thread
  • squeak93
  • Feb 20, 2026
1996 - 2004 SN95 Mustang -General/Talk- Yesterday at 8:17 AM
squeak93
R
2004 convertable help
  • realbkg
  • Jun 4, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jun 4, 2025
realbkg
R
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
