Gearing question
  • Thread starter Thread starter blindoboy87
  • Start date Start date Aug 30, 2006
blindoboy87
11
Dublin, OH
Aug 30, 2006
  • Aug 30, 2006
the guy i bought my 5.0 from said that it has a 3.73 rear end and id like to be able to confirm it. is there an rpm chart i can refer to? if it helps, at 80mph im turning ~2700rpm
Dayzed50
106
Marysville, WA
Aug 30, 2006
  • Aug 30, 2006
jack up the rear of your car and support it on jackstands. mark a rear tire with chalk,marker, ect and also make a mark on your driveline. count how many turns (by hand) of your driveline it takes to do one full rotation of your rear tire. this will tell you your ratio. 3.27:1, 3.55:1,3.73:1 ect. Charts can be deceiving as tire size differences aren't always accounted for. Hope this helps.
TRWXXA
190
RIGHT BEHIND YOU!!!... Made you look.
Aug 30, 2006
  • Aug 30, 2006
Make sure your speedo is correct too. You say you're doing 2700rpm @ 80mph, but gear swaps often result in inaccurate speedometer reading if care is not taken to put in the right speedo gear for the rear end/tire combo.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Aug 30, 2006
  • Aug 30, 2006
Follow what dayzed said..
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Aug 30, 2006
  • Aug 30, 2006
sounds about right..........
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Aug 31, 2006
  • Aug 31, 2006
I would guess you have 3:73's...
What size tire you got?
Smaller than stock tire, you could have 3.90's.
Bigger (taller) than stock tire, you could have 3.55's.
Ballpark, you probably have 3.73's.
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
3K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
