Gears! Do it yourself or take it to a Shop
GRGT1994 said:
You might be a little off there. The proper spec for the pinion pre-load torque is 16 to 29 inch pounds if you are using a new crush sleeve. Your 140 foot pounds equates to 1,680 inch pounds. So you would exceed the proper spec by at least 1651 inch pounds (or 137.583333 foot pounds, since you seem to prefer that unit of measurement).
At the proper spec, your 18 inch biceps would work just fine with any inch pound torque wrench.
I have done gear installs. Your correct is saying that the preload is 16 to 29 inch pounds. Preload is the resistance needed to turn the pinon assemble without the ring gear installed. You must tighten the pinon nut in small increments and remove your breaker bar and measure the preload with a inch-pound torque wrench. You must creep up on the preload setting. If you exceed it, you need another crush collar. It truely takes about 140 foot pounds of force to crush the collar. Anyone who has installed gears experience this.
It's so incredibly easy once you understand what to do. Took 3.5 hours my first time, but I had access to a lift. Read the link in my sig, and all links therein.
PM me if you have any questions. I don't mind helping out at all.
Scott
Well I took mine to the shop 3 times and so far every time they whine. They are telling me im making too much power for these gears and i need a hardened gear. Pretty much everytime I have brought my car to a shop sometihng gets ****ed up or something breaks so I have pretty much resorted to doing everything myself. Once I get tired of the whine(which isnt that bad this time) i plan on re-inswtalling gears/axles/ locker mywself in my garage/ parking lot if im in college.
I'm going to do mine myself when I get them but I have an auto craft center on post :banana: they have everything and the mechanics help you out for free when you hit a wall on somethin your doin if your nice to them
Thanks for the comment Kevin. That is exactly why I am doing my own gears.
I just got done doing a friend of mines. It took awhile but they have no whine and feel pretty good. I have done mine twice and his twice now. I'm almost a pro.
I dind't know how to do it when I started. However I am mechanicaly inclined and a machinest also (access to press).The hard part is crushing the crush sleeve. The other is setting the backlash between ring and pinion then preloading the bearings once its set.
MadHandle8169 said:
O yeah I have like jacks and stands but that's not that high of a lift. So maybe I should just pay it and get it over with. The shop I'm going to is a very reputable mustang shop on the east coast and I was told that there is a warranty on the install.
There is a shop in pottstown PA that will advertises 3.73 motorsport gears for 300 installed. That doesn't sound like a bad deal at all. if you need or want more info, let me know.
