GEARS, how fast will it go?
  • Thread starter Thread starter patboy
  • Start date Start date Nov 16, 2006
patboy
38
Dallas TX
Nov 16, 2006
  • Nov 16, 2006
All right I've got a 93 coupe with the tko 5-speed, with headers, ud pulley, and exhaust
I just want to know what the stop speeds will be if it had the 3.08 gears, 3.55 gears, or 3.73 gears.
W
WilwoodFiveO
108
VA
Nov 16, 2006
  • Nov 16, 2006
[/QUOTE]
here these are some charts
and it should be about the same with the tranny, U/d and exhaust dont really effect speeds.
W
WilwoodFiveO
108
VA
Nov 16, 2006
  • Nov 16, 2006
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Nov 16, 2006
  • Nov 16, 2006
With your limited mods, the car will hit an areodynamic brick wall somewhere about 130-135 MPH. In fact, 4th gear may by faster top end than 5th. It won't make much difference what gears you have, since the engine power will limit the top speed.
Depending on what model TKO you have, the 5th gear drive ratio can be wildly different from the stock T5.
Since the top speed is a function of RPM, gear ratio, & tire size, use the calculator at http://www.corral.net/tech/gearcalc.html
Drivetrain How much resistance, if any at all, is normal on a new 1st gear and synchro on a WC T5 transmission?
  • sleep-e
  • Jan 21, 2026
Fox 5.0 Mustang Tech Jan 22, 2026
sleep-e
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Fox Xtremely high fuel consumption
  • PonyGTrider
  • Apr 11, 2026
  • 9 10 11
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
PonyGTrider
