gears install
1LowGT
294
st louis mo.
recently i got aggravated over high prices with installing gears so i decided that i want to install my own,does it sound like a good idea??? i have alot of mechanical experience but none installing gears,does anyone know where i can find the full info on lining the gears up?? pinion depth and backlash settings and procedures?? or should i just wait until i get the $600 to have the speed shop do it?
No, it does not sound like a good idea at all.
You will need:
Magnetic base dial indicator
Inch pound torque wrench
Skill
Knowledge
Experience
If you do not have these things or know someone that does, I recommend you have it done by your local Ford dealer or a good speed shop.
Definitely recommend getting someone else to do it. It is not an easy job like on some cars. I'm not sure a local Ford dealership will install even Ford Racing gears as I know I've inquired several certified Ford Service centers around my area and they don't do any kind of service with aftermarket parts whether its Ford Racing or not. $600 is for everything I imagine...I know by me its a little above $500 probably close to $550 once tax is included...so is it a bit more expensive, yeah but not that much.
it is hard to do ive done a couple on the floor with the car on jack stands and it is a PITA because you have to get the black lash the depth and the rotational torque and alot of other things thas why i wouldn't recommend it if you've never done them just have someone else do it if its $600 for everything that's cool because once in a while when you are taking the bearing off the pinion ring it gets damaged and you have to replace it. :D
I've gotta agree with Kilgore - not a good idea to take this one on yourself (practice on your friends F-Body first :D )
But seriously, how much is too much? It is an involved install. I paid $200 labor, plus fluids...ending up to be $220. To me, that's a bargain considering what is involved and the fact that it's something you don't wanna have to do twice (or f'up in the process).
I am impressed with how many people do their own gears and at least don't tell us of the problems afterward. I have always worked under a lift.
Lay on the ground and try to get leverage for a crush collar? pinion shims? putting the carrier in and out a few times to get the shims right ( damn, I dropped one, did it come out the left or right :D ) If someone has the time , patience, decent tools and someone with experience, go for it. Otherwise this mod is best to be done by a shop.
