General Wire question
Because I'm taking those wires out, its a completely new harness and the wires are a tad bit shorter. I measured em wrong :(
I'm planning on using expandable black sleeving to cover up the wires. I believe it is also fire resistant.
I'm using 3/4" black corragated wire loom and have my entire harness running right there just like that. It isn't perty, but it keeps the wiring out of the way.
Thanks, I'll post a pic of my work tomorrow, I did the entire car's wiring today and my arms are beat! I still have to wire head lights but it started up!!!
Does anything connect to the I terminal of the starter?What i did with wiring is my headlight stuff goes where the red line is above, the wires going to the starter and alternator go really close underneath next to teh cowl, then under the export braces to teh back of the shock tower and then over the shock tower to the starter. A similar set up is used for teh temp sending, oil sending, and tach and pos coil wires.
